18s on an S4 FC
Old Oct 13, 2004 | 07:49 PM
Element's Avatar
18s on an S4 FC
i was offered a good price on some
Tenzo r RS5 18/7.5 with a 114 5 bolt pattern
and
215/40zr18 tires
does any one know if these will fitt on my 88 TII
I dont know the offset cant find that info.
thankyou
Old Oct 14, 2004 | 12:37 AM
ARD T2's Avatar
What is the offset of the wheels?
Old Oct 15, 2004 | 01:18 PM
Element's Avatar
I cant find that info
but they are the
Tenzo R RS5
Old Oct 15, 2004 | 08:34 PM
RETed's Avatar
It's useless without offsets.
If you have access to them, you can measure "backspacing"...
-Ted
Old Oct 15, 2004 | 08:38 PM
RETed's Avatar
I checked my 2003 Nippon Racing (same company as Tenzo R), and they don't list an 18" RS5 explicitly - they only have a 17" version listed.
Most of the other model rims show a 18" x 7.5" +45mm offset.
This is kinda tight, so it might or might not work on your FC.
Expect to run some small spacers if it doesn't clear up front.
-Ted
Old Oct 16, 2004 | 11:29 AM
Element's Avatar
Tight how to closs to the fender or to the brakes and
front or back
Old Oct 21, 2004 | 04:22 PM
ProjectRESuperG's Avatar
Tight as in close to brake and suspension components. The greater the offset, the closer the inside rim is to the suspension. The smaller the offset, the further out towards the fender the wheel is. Hope that makes sense.
Old Oct 21, 2004 | 04:24 PM
Oh, btw, yeah, 45mm is kinda close (too big of an offset), the stock wheels are 40mm. With a 7.5" wide rim, I would stick with something at least 35mm in offset.
Boosted11
Jan 19, 2008 03:23 AM
Rotogod
Mar 20, 2003 01:26 PM
