will rims this size rub the fenders with my suspension mods?
Old Oct 12, 2004 | 12:26 AM
artguy's Avatar
WTB** Very Low Miles 94-95
18" wheels....No idea what offset.... 285/35R-18 Michelin Pilot MXM's rear, 245/40R-18 front.
I have H&R springs and Koni Yellows...will these rims be too big even with rolled fenders?
Old Oct 12, 2004 | 01:00 AM
artowar's Avatar
FD3SW211E55
The answer is a definite "maybe" without offset info. With offset info, the guys here can at least give you a "probably yes" or "probably no"
Old Oct 12, 2004 | 01:13 AM
Rx-7Addict's Avatar
Rotary Powered
not much we can tell you without knowing the offsets. 275s almost always fit in the rear without rubbage.. 285s sometimes will, depends on the tires and drop... rolling the fenders should allow a 285 rear
Old Oct 12, 2004 | 01:24 AM
SpeedKing's Avatar
Power Trippin'
Yep, knowing the offsets is a must. The fronts are almost 1" larger in diameter over stock, so adjustable coilovers and rolling the fenders will probably be needed (assuming the offsets are within range). And with the 285s out back (10" wide wheel?), you may need aftermarket trailing arms/toe links to clear.
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
