West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Need some help with exhaust
Old Oct 9, 2004 | 01:28 PM
Icemastr's Avatar
All Motor
So I was removing the stock exhaust manifold from my 99 Miata to install a RB 4-1 header and I couldn't get two of the three bolts that hold the exhaust manifold to the front pipe off. I thought I could just pull the manifold and front pipe up through the top of the engine bay and I got the flange for the manifold to front pipe up past the bar right there but now its stuck, it won't go back down or up. I don't know if I can drive the car as is since the exhaust ports would just blow right out into the engine bay, so I don't know if I can drive a few miles to a mechanic to get the bolts drilled out or just cut the pipe. If there is anyone near me in Mission Viejo, CA that has a cutter or a drill/drill bits that can drill the bolts out or cut the exhaust pipe so I can seperate the front pipe since its catching on the transmission please PM me or reply to this thread thanks. Hoping to get this finished up soon since my girlfriend is pissed about not being able to drive her car.
Old Oct 9, 2004 | 09:46 PM
Icemastr's Avatar
All Motor
Free beer?
Old Oct 9, 2004 | 10:20 PM
Siraniko's Avatar
RX for fun
how about gas..super unleaded please. I own a 99 Suburban 4x4 with dual tanks
Old Oct 10, 2004 | 12:21 AM
Jesuscookies's Avatar
I can haz rotary?
Double check that your muffler bearings have been properly aligned. If so, you should have no problem removing the bolts with a set of tweezers. <--- See who said I wasn't helpful ?
Old Aug 2, 2005 | 10:50 AM
geargrabber's Avatar
I rolled down a mountian
did everything work out in the end?
Old Aug 2, 2005 | 06:29 PM
SERIES7's Avatar
Embassador to SOY
Yeah, he got his rear end worked
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
Sep 4, 2015 01:41 PM
