1981 Mazda Rx7 -Vs- 1996 Dodge Neon
Ok this is crazy. Knowing that I have a sport car but yet my girlfriend neon have more horsepower than my car. LOL! This is the battle Between Rx7 & Neon. If this two stock cars were to race. Which one would ya think it will win in a 1/4 miles and why? Also I know that the drivers would make a big different but just assume both drivers are great so the differents is not on their driving skills but more in the cars stock peformance.
1981 Rx7 GS 2DR Coupe ( Stock )
Info:
Engine Specifications
Engine Type: Twin Rotor 12A 100 @ (75 kW) @ 6000 rpm
Displacement: 1146cc/70ci
Compression Ratio: 9.4:1
Output(hp): 100bhp @ 6000 rpm
Torque: 105lb-ft @ 4000 rpm
Fuel Supply: Downdraft, Two stage, 4 barrel carburetor
Weight: 2,335 lbs.
*Review Note* "The engine produced 100 horsepower (75 kW) @ 6000 rpm, allowing the car to reach speeds of over 120 mph (190 km/h). Because the engine was so smooth, with no excess vibration or harsh noise at high rpm, a buzzer was fitted to the tachometer to warn the driver when the 7000 rpm redline was approaching."
1996 Dodge Neon 4DR Sedan ( Stock )
Info:
Standard Engine: 2.0L 131 hp I4
Horsepower: 131 @ 6000 RPM
Torque (lb-ft): 128 @ 5000 RPM
5-Speed Manual Overdrive: Std.
Weight: 2343lbs <--- ( Weight Rading from a 2 DR Sport ) *I can't find the darn weight reading for the 4DR Sedan*
Info:
Weight: 2,335 lbs.
Info:
i raced sooooo many neons (mostly on the highway) back when all i had was exhaust. i would PWN them pretty bad. seriously, they might be rated at the numbers you posted, but i've seen them on the dyno and it hardly reflects that. you can take one easily.
Originally Posted by 82SilverRX7
Neon's are slow.. I'd put my money on the 7 any day
My '82 beat a 2nd gen eclipse and I'm sure eclipse's are faster than Neons
I have also run Neons at the track (1/8 mile), with a header and a decent driver they run 9.9, which is a little quicker than what my SE does. I have no header though, just a straight pipe, so without the header they are about the same. I would say depends on the drivers.
Trending Topics
I've had both a 99 Neon RT and a 85 RX-7 GSL and stock the neon is just a little quicker from the jump but the 7 pulls harder in 3rd and 4th. Both with headers, exhaust, and intake the 7 is stronger all around.
