Power FC wont run past 5 seconds
Old Sep 28, 2004 | 05:40 PM
boostracingfd's Avatar
Unhappy wont run past 5 seconds
first ill tell u about the car...... street ported motor, 35/40 single, all block off plates installed, 1000cc prim. 1600cc sec. with resistors, aeromotive fpr, runnin 40 psi, supratt pump, pfc and commander pre mapped by rx7 store to support my mods.
anyways the pfc is installed and the car starts but only runs for like 5 seconds, if u step on the gas it dies, if u try to let it idle it dies.
the car runs with stock ecu but sounds like a chain saw (real ruff) shakes like hell and the exhuast is rich as hell. not sure what it is either programming, vacuum leak, or something else. also i dont have my o2 sensor hooked up will that matter? well any ides guy any ideas would help.
thanks jay
Old Sep 29, 2004 | 12:28 PM
cewrx7r1's Avatar
Eye In The Sky
It will not run smoothly with a stock ecu because of the 1000cc primary injectors are flooding you out.
With the PFC, evidentially you are still mismatched with the 1000cc primaries not set up properly. You really need a datalogit to properly set up the PFC for your
injectors. Sizing, lag, overlap, and inital secondary pulse width.
You could play around with the IGL/IGT - INJ screen to quickly add or take fuel out.
Old Oct 16, 2004 | 03:10 PM
someday.... youll be dead
sorry to bring up an old thread, but curious if you ever got it running and how you did it.
Old Oct 25, 2004 | 09:36 PM
still not runnin
thought it was the pfc becuase it wouldnt even run with it but would start and idle with the stock ecu. sent it back to rx7 store and they checked it out on anouther car. they said it worked fine. they remapped it for what i need so just waitin to get it back. ill recheck to make sure the right wires were pulled from the harness. but if anybody has any other suggestions that would be great
Old Nov 21, 2004 | 04:48 PM
RXJJang's Avatar
under construction...
Any updates on your car? I seem to have similar problems as I upgraded to gt35/40r also (with 550/1600cc, hks twin power, etc). My car will run for 4-5 sec and then dies; I can keep it running, however, with some throttle input. As in your case, I think it might be a PowerFC map problem (going to get it tuned this Sunday) or a vacuum leak. Please let us know if you have had any success with your new maps.
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
86glxNA
Aug 18, 2015 03:33 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
