quick/simple T04R questions
Old Sep 27, 2004 | 12:29 PM
Ryde _Or_Die's Avatar
Ok I just had a few easy questions. Does the HKS T04R say "HKS" on the front comp housing or no? Are all HKS ones divided or collected or do they offer both? Are they all v-band? What are the differences between the HKS and standard garrett T04R? Thanks alot.
Old Sep 27, 2004 | 03:30 PM
ZoomZoom's Avatar
SEMI-PRO
I'll tell you right now the HKS T04R is sized differently then the one sold to the public by Garrett. Garrett makes Both but the sizing is closely guarded by HKS. You will make more power with the HKS hands down. Its been proven over and over.
As far as the details about kit you should call HKS
Old Sep 27, 2004 | 03:48 PM
I appreciate the response and no offense whatsoever, but thats not what I was really looking for. Someone is going to sell me an HKS one, and I want to be sure its HKS and NOT a Garrett. I just figured some people on here had them. Thanks though. As for asking what the differences were, I was just hoping someone knew the exact difference or at least a reference between power from each turbo.
Old Sep 28, 2004 | 04:35 PM
Does anyone know if I go with a non-HKS T04R do you guys think it will hold 20psi to redline if I run a .84 p trim turbine side?
Old Sep 28, 2004 | 09:19 PM
so whats wrong with the garrett ones?? also, what is the power difference?? like 5-10 hp or is it more?
-Roman
Old Sep 28, 2004 | 10:58 PM
1revn3rdgen's Avatar
They say hks on the compressor housing and could be divided or non-divided and the to4r isn't v-band.
Old Sep 29, 2004 | 12:11 AM
So ALL T04R's say "HKS" on them? Thanks alot.
Old Sep 29, 2004 | 01:25 AM
Sorry, i meant on the turbine housing not the compressor housing.Yes, they should all say hks on them.
Old Sep 29, 2004 | 09:12 AM
Ok, thanks.
Old Sep 29, 2004 | 10:49 AM
0110-M-P's Avatar
Too Many Projects
I don't think you would be able to hold that to redline with a .84 trim. Just my opinion. My .84 A/R TO4R held my 14.5 psi to to about 6900-7000 and then would drop between 14.0-14.5. So i really don't think that it would hold 20 psi till redline. BTW, I will still using stock ports and that would probably have a difference.
Old Sep 29, 2004 | 01:56 PM
ZoomZoom's Avatar
SEMI-PRO
What Im telling you is they are both Garrett turbos. But the one sold under the HKS label is sized differently.
The power difference is substantial. Like 40-50+ hp at the same boost levels. If you have a question about HKS turbos your best bet is too call them. You will get varied responses on here. Most of them unreliable.
Old Sep 29, 2004 | 03:28 PM
Hm, definitely something to think about I guess. I changed my mind to the .84 after someone on here (I believe him name was carl) said he made like 450rwhp on a .84 but that was a different turbo I believe. Will a big streetport help or hurt with holding boost? Thanks.
Old Sep 29, 2004 | 03:29 PM
I know they are both garrett turbos and HKS has garrett do something to them. I am getting mixed answers. I've had people tell me they are virtually the same with a clipped turbine wheel. Others have told me its like a GTQ wheel or something. I'll see if I can find a number and get ahold of them. Thanks for the help.
Old Sep 29, 2004 | 09:54 PM
0110-M-P's Avatar
Too Many Projects
I really wish I had chosen to put a large street port on mine. I think it really would have helped overall. Made more power, faster spool, but i don't know if it would have helped the loss of power at 7k or not.
Old Sep 29, 2004 | 11:07 PM
Call 411 and ask them for hks's number they're in Gardena, CA off of Main St.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
