Sponsored by: CARiD
N/A to T3 super60--HELP
Old Sep 25, 2004 | 11:03 PM
ian915's Avatar
I have a couple of questions about turboing a n/a engine
-should I get a turboII ecu? or will my stock unit work with an fmu and injectors?
-where is the best place to tap an oil line in for the turbo?
-where the hell can I mount a 22"x19"x4" intercooler?
-Anyone have any tips for turboing a non-turbo car (ie- hints, tips, what works well?)
-I don't want to spend a lot on coilovers, what would be the best springs and struts for a total drift set-up?
Thanks to anyone that can help.
My car
87 se, 5speed, getting a t3 super 60 and a crapload of suspension parts
Old Sep 27, 2004 | 09:54 PM
mickmania's Avatar
if you wanna turbo you n/a. you need alot of parts.
The n/a to turbo swap costs around $4000
turbo II engine
turboi II tranny
turbo II ecu
turbo II afm
Turbo II driveshaft
Turbo Ii rear end
Turbo II halftshafts
Turbo II knock control box
Turbo II fuel pump
Turbo II alternater
Turbo Ii starter
alot more cna't think of them right now
Old Sep 28, 2004 | 12:16 AM
DerangedHermit's Avatar
He's not talking about switching his car over to a TII. He's talking about putting a turbo ONTO his N/A engine.
Old Sep 28, 2004 | 08:59 PM
RETed's Avatar
T3 Super 60 is kinda small.
It'll barely make about 200hp, unless you crank the boost way up.
-Ted
Old Oct 6, 2004 | 09:16 PM
ian915's Avatar
The T3 super 60 has the same inducer diameter as the popular T3/T4 conversions.
Compressor spec.: 1.9" inducer, and .50 A/R.
Turbine spec.: 2.26 exducer, and .63 A/R.
I actaully thought the thing was pretty big, I'm used to working with IHI's, I was actually thinking it will make about 280 whp.
Any suggestions other suggestions?? I appreciate any help guys.
Old Oct 6, 2004 | 10:59 PM
RETed's Avatar
This can't be true.
By definition, a "T3/T4" hybrid uses a T4 compessor section.
Almost all T4 compressors are larger.
Are we talking about piston engines?
You need to drop the power output by 10% to 20% due to the higher BSFC on a rotary engine.
-Ted
Old Oct 7, 2004 | 12:55 PM
ian915's Avatar
hmm... see, I'm learning something new everyday!
any ideas on a good place to tap for an oil line? I was thinking the oil pan, but I don't know if it will have enough pressure.
Old Oct 10, 2004 | 09:41 AM
wyt r1ce's Avatar
http://www.aaroncake.net/rx-7/naturbo.htm
im gunna do the same thing..
Old Oct 12, 2004 | 01:09 PM
ian915's Avatar
Thank you, I new I couldn't be alone on this one. Big help, I'll keep you posted on how mine goes
rxlevi7
Sep 26, 2015 07:28 AM
mulcryant
Sep 9, 2015 05:24 PM
