Promoting the Half-Bridgeport Turbo Setup
Old Sep 22, 2004 | 04:46 PM
BDC's Avatar
BDC
BDC Motorsports
Cool Promoting the Half-Bridgeport Turbo Setup
I've posted this thread on the NoPistons forum as well earlier this afternoon.
Cut/pasted from there:
My buddy Eric Ramirez and I shot some video on his digital camera last night for awhile. It'd been a long, long time since I had any running video of my car (well over 2 years) so I got a wild hair up my rear to go take some. The videos turned into a "let's prove to the world that half-bridgeported turbo setups actually work" since there's hardly any video of them out there as of yet. All we did was drive around for about 2hrs filming and taking pictures here and there. I believe we took about 5 minutes of video from several different types of perspectives: Outside, idling, at a streetlight, starting, low-end driving, etc. Even though the lighting sucks (probably the camera used, plus it was 10pm at night), these videos clearly prove that this is an efficacious and worthwhile setup as some of us have been saying for months.
The engine in my car is a Series 5 block w/ series 4 rotors (the originals in my 424hp motor from nearly 5 years ago), milled to 3mm using Rotary Aviation seals, solid corner seals, series 4 front counterweight, and Series 4 Racing Beat 17lb steel flywheel. To add insult to injury, the clutch I'm using is an ACT 6-puck UNSPRUNG disc w/ heavy pressure plate and new-ish hydraulics. Supposedly not streetable with both the BP and harsh clutch, right?
These videos have been modified from their originals to add more lighting, better vocal sound, higher quality, as well as smaller size. Comments and criticism always welcome. Right-click and Save As to download. Enjoy.
http://slammedblk7.cyberosity.com/bdc
Check out the smaller videos entitled "Video_x.wmv" and download them over the ones listed as "Picture x.mpg".
B
Old Sep 22, 2004 | 09:17 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Linky no workie for me as of now. Possibly to many people? possibly something else?
Old Sep 23, 2004 | 01:08 AM
BDC's Avatar
BDC
BDC Motorsports
Might be. Try this link: http://slammedblk7.cyberosity.com/bdc See if you get anything.
B
Old Sep 23, 2004 | 03:02 AM
RICE RACING's Avatar
Talking
"Say it's hard to start a bridge port up ?"
Old Sep 29, 2004 | 02:41 PM
SnowmanSteiner's Avatar
Ga-nome liberator
I have to give ya bump. I've ridden in a half bridged car with a GT40 and with a 60-1 and with both setups the car ran great. I never saw a problem with low end, or not being able to use the power band. From what I've seen of Brian's work it's incredible. Good job, and keep up the great work, the rotary communitty owes you a big thanks.
- Steiner
Old Sep 29, 2004 | 02:56 PM
BDC's Avatar
BDC
BDC Motorsports
Well thank you Steiner
B
Old Sep 29, 2004 | 05:59 PM
z8cw's Avatar
Nice demo. Thank you.
So what was actually the upside? You proved the doubters wrong, except for reliability which nobody knows yet. What are your numbers over a street port with what set-up?
Thanks
CW
Old Sep 29, 2004 | 06:19 PM
BoostedRex's Avatar
NorCal 7's Co-founder
I have ridden in the same car as Steiner. I know that I'll be talking to BDC when it comes time to rebuild my TII. And from what I heard about BDC's visit to SC, it couldn't have gone any better than it did. You're tha man BDC!!
Zach
Old Sep 29, 2004 | 06:20 PM
Aesop Rock's Avatar
Will Work For Apex Seals
Nice, im going half bridge with my rebuild. What standlaone do you run?
Old Sep 29, 2004 | 06:31 PM
BDC's Avatar
BDC
BDC Motorsports
I use a Haltech E6K with 720 primaries and 1680 secondaries. For now, I'm using the Supra Mk4 pump but plan on changing that around sometime. I'm not sure yet how I'll reconstruct the fuel system.
B
Old Sep 29, 2004 | 09:39 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
brian,
i suggest you take a careful look at the kenne bell boost a pump... it should solve any fuel delivery challenges w your pump. visit kenne bell's excellent site... lots of engineering.
regards,
howard coleman
Old Sep 29, 2004 | 10:14 PM
next time get on dat ****! I wanna hear a half bridge scream! haha
sounds good B
Old Sep 30, 2004 | 12:51 AM
Rx_treme's Avatar
yes I have spent many a weekend at BDC's house last year. He's Very knowledgable and does Immaculate Work. I was impressed to say the least.
And the HBP T66 car i rode in was absolutely insane.
Old Sep 30, 2004 | 12:03 PM
Ga-nome liberator
The benefits of a half bridge over a streetport for the most part is power. The half bridge allows a considerably larger amount of air to enter the combustion chamber. Depending on the type of porting you get this will also effect when the air first enters the chamber and when the chamber is completely closed. The most common problems that people complain about is idle, low end power, and reliability. The 1/2 bridge car that I've ridden in had an idle around 1100 to 1300 but usually stayed around 11. This is not bad at all, it is easy to get the car rolling. As far as low end power loss, there is a loss but the mid to top end power that you gain is overpowering. With a 1/2 bridge you can also upgrade to a larger turbo than you could run effectively with a streetport. This increases the mid range and top end power incredibly. The other common problem is starting, because you have such a higher amount of airflow, people "complain" about it being hard to start. As evident in Brian's video this is obviously not a problem he is experiencing. In the car that I've ridden in as well it wasn't a problem. Unless you are running 100 % injector duty cycle at idle and start up, you really shouldn't have problem. A lot of how it is going to run is in the tunning, which goes the same for a streetport. With halfassed tuning no car is going to run well, or develop the power that it is capable of. So there is no difference between streetports and 1/2 bridgeports as far as that goes. You either pay to get it tuned well or you live with a half assed tune. Brian will definately be getting my business whenever I get around to getting my car running again.
- Steiner
Old Sep 30, 2004 | 01:57 PM
Aesop Rock's Avatar
B
Im going to run a walboro, on my car. 680 primary, 1000 secondaries. However the standalones up in the air soon, hows the Haltech work? any bugs?
Old Sep 30, 2004 | 09:08 PM
Ga-nome liberator
I've heard good and bad about the Haltech. Personally I never had any problems with mine, it worked fine for me. Some people have had problems, I don't know specifics off the top of my head.
- Steiner
Old Oct 1, 2004 | 02:35 AM
12at's Avatar
10.21 @ 137mph
Talking
What sort of hp is it putting out?
Sounds great by the way.
Old Oct 6, 2004 | 07:53 PM
Aesop Rock's Avatar
BDC....where'd ya go?
Old Oct 6, 2004 | 08:06 PM
BDC's Avatar
BDC
BDC Motorsports
I'm still right here.
What's up?
B
Old Oct 6, 2004 | 08:08 PM
BDC's Avatar
BDC
BDC Motorsports
- Steiner
My main experience in Haltech products is their E6K/E6X line. I have installed one E11v2, and I *really* liked it, bu t the same ECU in question wound up blowing some sort of protective internal circuit or something. I'm not sure if it's related to the heat problem some of them have been having a bit but who knows. I vote for using an E6K or E6X as they're time tested and proven.
B
Old Oct 6, 2004 | 08:11 PM
BDC's Avatar
BDC
BDC Motorsports
That'll work just fine for a mid-sized T4 setup like a TO4E 57 or 60 trim.
B
Old Oct 6, 2004 | 08:18 PM
Aesop Rock's Avatar
B
ehh....I'm gonna be running an Eaton M-90...in a half bridge, its a lot of custom work, but i can't land a turbo engine for the life of me, so im re-designing the intake manifolds and all to fit the supercharger after the throttle body
Old Oct 8, 2004 | 11:54 AM
Ga-nome liberator
Same here, mine was an E6X, but with a friend's new purchase hopefully I'll be able to see what a higher Haltech can do. I have heard of the E11's having overheating problems. I'm surprised Haltech hasn't done anything about it yet. But I have also heard good things about microtech and wolf, I just haven't had a chance to actually work on one, so don't really have a basis of comparison.
- Steiner
Old Oct 8, 2004 | 05:54 PM
Rotortuner's Avatar
Undercover
It sounds good. And ya i think bridge port are completely streetable. I had a half bridge, non turbo in my rotary truck, and i towed huge trailers and everything with it. I towed a double axle car hauler with a 4k pound volvo on it.
My T2 swapped 81 fb runs a light flywheel with an unsprung 4 puck disk and a race pressure plate, no issues there. as long as your not in bumper to bumper stop and go for more than an hour that works fine too. I was a little dissapointed, i wanted to here youi rip it through a couple gears! How much power? and what turbo?
CJG
Old Oct 9, 2004 | 09:24 AM
RXTASY1's Avatar
Here is a clip of my BDC halfbridge.
Sorry for the size! I hear bigger is better?
http://www.idahorotary.com/bridgeport.mpg
