when will it end? (turbo removal)
Old Sep 14, 2004 | 09:29 PM
superstock2's Avatar
Boss
after removing the devils bitches, oh did i say devils bitches cuz i meant heat sheilds! and all the manifold to engine and turbo to manifold nuts, and all of the coolant line and oil lines, the turbo will move and so will the manifold but i still can't get it off. please help oh yeah its an 87 turbo
Old Sep 14, 2004 | 09:47 PM
hondahater's Avatar
spending too much money..
its a bitch I'll tell you that much you just have to find the best way either from the top or bottom and pull it out. Also your not trying to pull the mani and turbo at the same time are you??? I can do that with my car cause I have no a/c and other stuff however if your car is relatively stock then you should take the turbo out first then the mani.
Old Sep 14, 2004 | 10:03 PM
Boss
i don't have a/c or power steering either but thanks for the advice and keep hating those hondas! maybe i haven't got all the bolts off?
MountainTurbo's Avatar
I pulled my manifold and turbo out together on my 88TII (still have AC and all smog stuff too). I ended up pulling it out through the top. Took a little time, lots of sweat, blood, and tears though
Old Sep 14, 2004 | 10:07 PM
Boss
cool i'll have to give it the old college try tommorow!
Kenteth's Avatar
Like Ghandi with a gun
smack it.
(I've used this in many "it won't come off" threads. Its worked every time)
Old Sep 14, 2004 | 10:09 PM
Boss
Boss
Old Sep 14, 2004 | 10:10 PM
Boss
don't mind me just trying smilies! thanks for the tips
cristoDathird
28
May 30, 2019 08:47 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
