FD fuel pump install ?'s
Old Sep 14, 2004 | 02:39 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
what all is involved for installation? what do I have to modify/etc.
do I need to rewire it, or is the stock wiring sufficient to power it?
Picking it up tonight... probably put it in tomorrow.
Anything else I should do while I have the car apart?
Old Sep 14, 2004 | 02:46 PM
SonicRaT's Avatar
Super Raterhater
Just make sure you use a new sock, other than that, it's pretty straight forward, just remove the old one, put the new one in, and away you go. If your stock wiring is crap, then obviously rewiring is a good idea, but if it's fine, then don't worry about it.
Old Sep 14, 2004 | 02:56 PM
Turbonut's Avatar
The FD "sock" is too large and hits the float assembly not allowing it to drop when fuel supply low. I installed the FC, in tank filter, right onto the FD pump. Works like a charm.
Old Sep 14, 2004 | 02:59 PM
SonicRaT's Avatar
Super Raterhater
That's why you get a FC sock (new)
Old Sep 14, 2004 | 03:05 PM
Turbonut's Avatar
Just wanted to make certain he bought the FC filter and NOT the FD sock.
It looked like a sock on the FD pump, but my S5TII filter doesn't resemble a sock.
Old Sep 14, 2004 | 03:19 PM
SonicRaT's Avatar
Super Raterhater
Yeah, I know what you mean. The FC 'sock' is more of a oval rectangle, whereas the walbro/fd/etc had that actual flat sock looking thing, but I guess it's just stuck with me ever since then. Oh well.
Old Sep 14, 2004 | 05:19 PM
Terrh's Avatar
awesome! thanks
I've got a new one allready, actually. New fuel filter too. Both going in tomorrow
Queppa
Nov 18, 2024 03:47 AM
