Spark Plugs, Need Help
Old Sep 14, 2004 | 01:17 PM
wiseman's Avatar
Hi all,
I'm from Portugal (sorry my bad english), and i bought an adandoned 1990 Turbo II. The car was stopped since 1999, and because that, i change all the oil: Engine, Brakes, GearBox and Transmission.
The car looks fine but above 5000RPM have some break on rotation, the Lambda value is too high and the car is spending 30L of gas / 100Kms. It seems i have to change the Spark Plugs and maybe the wires too. The problem is that i can't find that here in Portugal. How many and witch spark plugs do i need? I heard 6, is it correct?
Tks.
Nuno Silva
Old Sep 14, 2004 | 02:50 PM
Turbonut's Avatar
4 Plugs NGK-2 BUR7EQ leading (lower) 2 BUR9EQ trailing (upper)
Make certain wires are to the correct plugs. Front coil to lower plugs, doesn't matter which one. Rear coil T1 to top front plug, T2 to top rear plug.
Old Sep 14, 2004 | 02:53 PM
Aesop Rock's Avatar
Will Work For Apex Seals
Denso makes some but I would go with the above statement
Old Sep 14, 2004 | 04:29 PM
wiseman's Avatar
Tanks i find it on NGK.COM
Are these good? BUR7EQP/BUR9EQP it seems the same but with platinium center electrode.
Old Sep 14, 2004 | 05:25 PM
Aesop Rock's Avatar
yes, thats what I have.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
