Whining noise from tranny/clutch
Old Sep 14, 2004 | 02:40 AM
Bob_The_Normal's Avatar
I get a whining noise that increases in pitch with engine speed...
It happens only in Neutral and in 1st. It goes away in 2ng gear.
And only when the clutch is out.
How much does a new tranny cost? heh... I wonder if it's even worth rebuilding one.
--Gary
Old Sep 14, 2004 | 02:42 AM
RotaryResurrection's Avatar
Tranny input shaft bearing...very common with rx7 manual trannies.
Old Sep 14, 2004 | 02:52 AM
Woo thanks for the fast reply Kevin! (In the PM too!)
My car seems to be the definitive "common problems" car haha. Suspected bad front Ujoint on the driveshaft too... the tranny vibrates... someone told me this was a common thing as well.
Wasn't someone making and selling a driveshaft with rebuildable joints? Is it much more expensive than a new stock one? Sounds like a good investment for what will hopefully be a DD/AutoX car.
--Gary
Old Sep 14, 2004 | 03:40 AM
ScrapFC's Avatar
Emerald Triangle for life
Mine has been doing the same thing since I got the car. I got another trans and have been waiting for it to get worse or act like it's about to fail. I've now been beating the **** out of this trans for 15,000 miles and it hasn't changed. I'm wondering if it has anything to do with my switching over to Redline synthetic? It might be a good band-aid to let you run on the poor thing for a bit...
Old Sep 14, 2004 | 11:37 AM
throwout bearing ... and a bad ujoint would give u a bad bad vibration around 30 40 50 60 mph right behind the shifter it sucks dude... ive had to change my shaft twice... those 4 and 6 puck clutches kill em i guess lol that was back in the n/a days tho
Old Sep 14, 2004 | 11:46 AM
throwout bearing
Bullshit. A TOB is only in use when the clutch pedal is PUSHED IN. The noise here is made when the pedal is NOT PUSHED, at which time the TOB is sitting idly by, about 1/4" away from the pressureplate, doing nothing.
Old Sep 14, 2004 | 01:52 PM
AZAutoXer's Avatar
Newbie
yup, mine too.
"Tranny input shaft bearing...very common with rx7 manual trannies."
that is what mine does too, and that is where the sound is coming from.
looks like i get to pull it apart.... <grumble grumble>
Old Sep 14, 2004 | 06:02 PM
It might be a damaged clutch release bearing...
But that's just a guess.
Old Sep 14, 2004 | 07:41 PM
Old Sep 14, 2004 | 09:07 PM
z4csl428's Avatar
From: Seymour, TN (couple miles west of the atlantic ocean)
so what exactly are you saying kevin? youre being unclear...
Old Sep 14, 2004 | 11:12 PM
Given the posts that show up on a daily basis on this forum, this would seem to be the case.
Old Sep 14, 2004 | 11:17 PM
DerangedHermit's Avatar
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
Linda_Lovelace
Sep 18, 2015 10:04 PM
zxrazorxz
Sep 14, 2015 07:21 PM
