gsl se injectors
Old Sep 11, 2004 | 11:19 PM
RotaryBuddha's Avatar
CURVE OF CONSTANT WIDTH
gsl se injectors
im wondering if running the gsl se injectors as secondaries will help a stock port n/a at all, or would it create problems like flooding and all sorts of other headaches.
Old Sep 11, 2004 | 11:22 PM
version13's Avatar
Exhaust leak
Unless you have anyway of controlling it, i.e. microtech, S-AFC, then it would do you no good. You'd be running really rich.
Old Sep 12, 2004 | 06:56 AM
would i be just running rich when i go WOT or would i be running rich at idle.
my plan is to do reted's fuel setup to get rid of the PD before it fails and to have a more constant fuel supply when i run nitrous.
Old Sep 12, 2004 | 07:34 AM
NZConvertible's Avatar
I'm a boost creep...
You have no need for that much fuel. Unless your engine is extremely modified, you're actually running too rich for optimum performance due to conservative factory tuning. Adding more fuel will simply reduce power.
Old Sep 12, 2004 | 08:32 AM
thanks for the info guys saves me some money
Old Sep 12, 2004 | 10:21 AM
Aaron Cake's Avatar
Engine, Not Motor
There's no reason to upgrade injectors in an NA unless you're making over 200 RWHP. You're already too rich. Grab an S-AFC, and lean the car out...
connerfd3s
Sep 19, 2015 05:58 PM
