will this bolt up?
Old Sep 11, 2004 | 11:01 PM
Dom_C's Avatar
will this bolt up?
will this manifold bolt up to an 86 N/A motor. are the manifold bolt patters the same on a turbo as they are on the N/A. if anyone has any info on this andhow much power it would make that would be great. thanks.
Old Sep 11, 2004 | 11:03 PM
Dom_C's Avatar
oops. heres the link http://pro-jay.net/images/semi.jpg
Old Sep 12, 2004 | 10:52 AM
Aaron Cake's Avatar
Engine, Not Motor
Should fit fine. You'll need to port match though.
Also, this is a Holley style carburetor manifold. To use it, you need to do a full carb conversion which involves reworking the fuel system, converting the ignition system to a distributer and many misc. things. In the end, it's not worth it since you already have an excellant fuel injection system and all electronic ignition...Get an S-AFC.
Jetlag
Sep 29, 2015 06:52 AM
