Disabling a rex
Old Sep 11, 2004 | 09:37 PM
WalkDMC's Avatar
your mother
Disabling a rex
Is there any part i can easily take out of the engine bay that will disable an rx7 so it cant be stolen? On other cars you can just pop off the distributer cap, but on a rotary...?
Old Sep 11, 2004 | 09:42 PM
Andrew.'s Avatar
The end of an era
Erm battery? Pull some fuses?
-Andrew
Old Sep 11, 2004 | 10:50 PM
RotaryResurrection's Avatar
almost anything electrical having to do with the engine...main relay, EGI or main fuses from fusebox, ENGINE fuse from internal fusebox, tons of stuff.
Old Sep 11, 2004 | 10:58 PM
harley71105's Avatar
Put in a blown fuse in place of the good one...that way if a thief checks the fuses for empty places he will most likely pass....
Old Sep 11, 2004 | 11:50 PM
sar's Avatar
sar
Doin a rebuild.
you could take off the fuel rail lol... that would really disable it....
disconnect the ignitors powering the coils
unplug the magnetic rotor position sensor...
unplug the fuel pump wires in the back left speaker post
if u really want to do the job u could drop the throttle cable from the throttle body... would prevent acceleration
unplug the ecu in the car.
Old Sep 11, 2004 | 11:57 PM
VietFC's Avatar
get an SAFC and keep it with you when you're not in your car.
Old Sep 12, 2004 | 01:09 AM
marlaman's Avatar
Need an E6x
if it's a manual there is a little plug under the dash, not exactly easy to get to, but yeah check it out, it's a green lttle hook shaped plug that connects 2 wires. i took it out just for ***** one time and she wouldn't start without it. and it only took me about 5 seconds to put it back in. Easy as pie.
Matt
Old Sep 12, 2004 | 01:25 AM
cezonetheillest's Avatar
i think that you could put one of those tire boot things and then they wouldn't even beable to steal it. lol. maybe just an alarm system
Old Sep 12, 2004 | 03:05 AM
Syonyk's Avatar
What level of "Keep it safe" are you looking at here?
A simple fuel cutoff switch (hidden) should keep most people from screwing with it. If someone really wants the car, there's nothing you can do that will prevent them from taking it.
-=Russ=-
Old Sep 12, 2004 | 04:17 AM
Madrx7racer's Avatar
-=Russ=-
I was going to say the same....or a BAtt. cut off......ignition disableing, like when the clutch is not depressed...
Old Sep 12, 2004 | 04:22 AM
Travelintrevor's Avatar
B.G.O.B.G.A.I.
take the motor out...J/K...liek they said...remove the egi fuse
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
12abridgeport
Aug 17, 2015 06:28 PM
