Pressing Brake Makes Lights Dim
Old Nov 25, 2001 | 12:03 PM
rico05's Avatar
WTB S5 N/A FC
Question Pressing Brake Makes Lights Dim
When ever I press the brake, my lights dim a little. Also, my idles at 1000 RPM (finally above 200 RPM!!!) but as soon as I press the brakes, it will drop to 500 RPM, and will idle rough. If I just sit there, it will idle at 900-1000 RPM for days if I let it! Is this a dredded grounding problem?!?!?
Old Nov 25, 2001 | 02:31 PM
Suparslinc's Avatar
It's Back!
mine does this a little too. I think its fairly common.
1)Vacuum leak in break booster
2)alternator bad
3)BAC or TPS??? I dunno
Old Nov 25, 2001 | 02:33 PM
Scott 89t2's Avatar
SOLD THE RX-7!
mine does it a bit too, but rpms only drop a tad before coming back up, if I sit there and pump the pedal the rpm just keeps going up and down a bit.
Old Nov 26, 2001 | 04:18 PM
MaxRX7's Avatar
hambre y sueño
my lights also dim, RPMS stays steady though. I will place an extra ground on the battery some time.
Old Nov 26, 2001 | 04:59 PM
Rx7-88na's Avatar
I have the same problem in my 89 --
It idles at 1000 but if i touch the brakes or open the roof/windows it drops to 500 then bounces between 500-800, i love electrical nightmares...Personally I thought it was my alternator, now taking other suggestions...
Old Nov 26, 2001 | 06:20 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
I had this problem too. I added some extra "main hot" wires from the alternator to the battery, and it helped a bit... but having an electric fan on a stock 88 charging system, is, well, a bad idea. I put an FD alternator on mine. No more problems.
www.geocities.com/rx7_ragtop and go to the "my car and mods" section. There's a link to a writeup on how I did it. EASY mod, and I've never had any reason to regret it even for a second. I now read about 14 volts at idle, and never go below 12 with EVERY accessory on, lights on, and foot on the brakes when idling.
That's with a big ole' Perma Cool finger-chopper fan. (That's a bad idea... there are MUCH better fans out there...)
Brad
astrum
24
Nov 15, 2017 08:44 AM
fastsaab
Aug 19, 2015 11:42 AM
smikels
Aug 18, 2015 01:26 PM
