Power FC Dattalogging rpm question
Old Sep 6, 2004 | 05:13 PM
kevinbtz's Avatar
Shell 93
Question dattalogging rpm question
I am in the process of trying to tune my car and I have noticed on a good pull, say from 4,000 to 7,800 rpm at about 13psi the rpm on the graph surges all the way up it like a saw blade...same thing with the bost at wot in the same rpm band the bost will do the same thing from 9psi up to 15psi. has anyone had the same experence when data logging?
Old Sep 7, 2004 | 05:43 AM
twokrx7's Avatar
Need more sleep
Not sure what you are seeing, may help to post a datalog for folks to look at. What you describe does not sound right unless your clutch is slipping or your wiring is messed up and sending erroneous signals to the PFC.
Can we assume you're running a PFC? your sig says stock ECU.
Old Sep 7, 2004 | 12:04 PM
cewrx7r1's Avatar
Eye In The Sky
Are you talking about the graph within the Commander or the DATALOGIT graph?
Old Sep 12, 2004 | 01:00 AM
kevinbtz's Avatar
Shell 93
it is a pms unit.....I know out datted
13
Jan 9, 2018 11:19 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
rx7shirley
Sep 2, 2015 02:11 PM
