carburetor conversion
Old Sep 3, 2004 | 10:14 AM
gerbraldy's Avatar
wtf's a piston
I have a spare s4 13b and I was wondering how to carburate it. Like what parts I need to get to switch it over. Do I just get a distributor from a fb rx7?
Old Sep 4, 2004 | 09:39 AM
chairchild's Avatar
50mpg - oooooh yeah!
you could just let the ECU handle the ignition side, and simply lob on a carb manifold and all te other mechanical bits
Old Sep 4, 2004 | 06:20 PM
rxtasy3's Avatar
i'd go after market on this one. check out racingbeat.com and mazdatrix.com. they will have intake and carb kits to fit the 6 port block.
Old Sep 5, 2004 | 08:53 PM
White_FC's Avatar
Having used the stock ECU to handle ignition before without the use of the AFM, I feel qualified to add some input here.
Don't do it that way.
It just does not work very well at all.
It would seem that the AFM plays a larger than (I) expected role in the ignition system.
I personally got it working 'ok' after a while, but after i've now installed a dissy from a S3 rx its alot smooth, especially since its now running a direct fire system on the leading plugs.
But other than that, if you want to use a 12a carb, or a rx4/5 13b carb you can buy adaptor plates that allow you to use either carb/manifold on a 6port block.
not sure where you are, but www.dysonrotary.com.au sells these adaptors. Obviously in Australia though.
