12a PP with Weber 48 ida
Old Aug 31, 2004 | 08:44 PM
Heath's Avatar
MAGNUM SE7EN
My 12a pp will soon be ready. The aluminum tubes that will be pressed in the housings have a 44.5mm inner diameter. I have a Weber 48 ida that I recently picked up. Can anyone with some experience offer some advice on carb settings (venturis, jets, ect.)? This will be my first pp motor and first time attempting to tune a 48 ida.
Old Sep 1, 2004 | 04:39 AM
Lasse wankel's Avatar
I would recomend using a 51 mm IDA w/ 42-43mm chokes, F-7 emulsion tube 240 main jet 160-170 air jet long air horns 100-120mm 0.9mm sqiurters and 300 needle valve. Good luck with your engineproject!
Old Sep 1, 2004 | 04:45 AM
Dude,
If you can get your hands on a Racing Beat Technical Manual, you'll get all the info you're looking for.
Old Sep 1, 2004 | 05:26 AM
karism's Avatar
Adolf Hitler Verfechter
Hi
Here is what Racingbeat recommends :
Peripheral Port Engine
(Equipped with open headers)
12A Engine
Venturi - 43mm
Fuel Jet - No. 230
Air Jet - No. 125
Emulsion tube - F-8
Needle Valve - No. 300
Hope this helps?
Karis
Old Sep 1, 2004 | 01:23 PM
Heath's Avatar
MAGNUM SE7EN
Thanks guys, I do appreciate your help!
dona1326cosprings7
Oct 29, 2015 06:47 AM
NLPerformance
Oct 2, 2015 07:11 AM
