Sponsored by: CARiD
rotary weight???
Old Aug 28, 2004 | 05:57 PM
rotaryguy_91's Avatar
rotary weight???
dose any one know how much a rotary engine weighs?
Old Aug 28, 2004 | 06:25 PM
diablone's Avatar
Be more specific, they are not all the same.
Old Aug 28, 2004 | 06:38 PM
marix1521's Avatar
Turn on Tune in Drop out
13B NA with a T78 and 5 speed tranny
yay, 400th post
Old Aug 28, 2004 | 08:01 PM
poor_red_neck's Avatar
Wait................What?
The answer is 42.
Really dude... I mean, there are over 15 different types of rotaries out there, not counting different variations of them!
I assume from your screen name you mean a Series 5 FC motor? N/A or Turbo? Shortblock or fully assembled long block?
SPECIFICS NEEDED!!!
Old Aug 28, 2004 | 08:31 PM
nevarmore's Avatar
I'm not the OP, but I'm willing to narrow it down.
The simplest method is to start with the weight of a 12a and 13b longblock in N/A stock trim. From there you can add in the weight of the turbos, which is fairly close among all cars and applications. Same goes for headers and such too.
For those inclined to tinker, we can start with the weight of the shortblocks and then add on the weights of the specific intakes, carbs, headers, water pumps, alternators, etc.. Once again the weights of a lot of the accessories are going to be the same among most makes and models.
Old Sep 1, 2004 | 11:12 PM
well i ment to say the 91 turbo 2 engine and the 3rotor of the JDM eunos cosmo sedan during the 1990s
Old Sep 7, 2004 | 09:51 PM
sar's Avatar
sar
Doin a rebuild.
I like how this didnt get answered at all. How much does each engine weigh, intake to exhaust manifold? Talking like 12a, 13b s4 (turbo), 13bs5(turbo), 13b-rew turboed, 20b.
Old Sep 7, 2004 | 10:39 PM
DerangedHermit's Avatar
I like how your original question sucked ***.
Old Sep 8, 2004 | 05:11 PM
Elysian's Avatar
Bimmer *****
well, the 4 port 13B in my repu(not origional, its something out of the 80s), was pretty heavy, but it was not heavy enough that i couldn't pick it up off the ground, and put it in the trunk of my car a few feet up... it was a short block tho
Old Sep 9, 2004 | 11:23 PM
locketine's Avatar
Road Rotary Aviator
Did you guys all just want to yammer or do ne of you know the weights of ne of the rotary engines? Is there a place to look up this info, I'd assume there is. I remember someone in here saying a LS-1 didn't weigh much more than a 13b and I thought that was complete bs but I have no idea what the 13b weighs except that u can pick it up urself.
Old Sep 10, 2004 | 10:47 AM
blueskaterboy's Avatar
Olympic Muff Diver
lets start with how much do the different rotors and housings weigh?
Old Sep 10, 2004 | 02:05 PM
Jeff20B's Avatar
Lapping = Fapping
This info is only semi-accurate, so it shouldn't be taken as fact.
13B
22 '74 13B carb and intake manifold
27.5 front plate Y
29 intermediate R5
34.5 rear plate Y
11.5 rotor
11.5 rotor
14 rotor housing
14 rotor housing
15.5 13B E shaft
33 flywheel (without P plate or clutch)
I'd estimate the tension bolts are about 5 or 6 LBS, but I could be wrong.
218.5 total without waterpump, alternator, P plate or clutch
Old Sep 12, 2004 | 03:57 PM
tjgosurf's Avatar
Squeak, Suicide Girls
You ******* rock Jeff.
Whoah, so I weigh almost as much as my engine. But I'm not putting out nearly that much hp.
1987 T2
11
Apr 1, 2017 11:59 PM
doritoloco
Sep 5, 2015 12:41 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
