Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
S4/S5/FD ECU/harness compatibility
Old Aug 24, 2004 | 07:40 AM
eyecandy's Avatar
Is it possible to use a S4 harness (engine) or ecu in a S5 car or vice versa? Or can you use a S4 engine harness with a S5 euc? I know this is a stretch and I know the Harness connector will need to be modified/rewired.
My other question is if you are running an FD UIM can you still use the stock ECU, because of teh FD TPS you need to use?
I also know if you want to run a PFC in an FC you can use the FD UIM, and you have to use an FD pressure sensor, so does that mean you could use an FD ECU? I guess as long as you could connect the harness and ecu right?
Old Aug 24, 2004 | 08:33 AM
autoxfc3s's Avatar
no the s5 and s4 have 2 difernt timings or something like that i beilve the s5 has a difernt e shaft or some thing? dunno but all i know is that its not worth the agravation of splising wires if it even is possible and if it isnt then....well it isnt
sorry i dunnno if that helped but i seriously dought if you can
Old Aug 24, 2004 | 01:29 PM
RETed's Avatar
No, the plugs are not compatible.
Possibly...
I doubt this would work correctly.
The Power FC is mapped for the 13B-REW.
Unless you have the master program and change the base map, there is no guarantee it'll work on an FC.
I don't know why you insist on using the P-FC.
There are a lot of other options that are priced competitively with the P-FC with more flexibility.
-Ted
Old Aug 24, 2004 | 03:45 PM
neofreak's Avatar
accept no imitations™
I have an AP Engineering PowerFC for FC, works like a charm, fired up first time. Uses FD pressure sensor. I sold my FC so its just sitting in a box though.
When you fire it up, it says 13BT instead of 13BREW btw.
Romeoxray7
Power FC Forum
15
Nov 20, 2015 01:38 AM
cosmicbang
Sep 25, 2015 03:15 PM
