83 smog failed, high CO?
Old Aug 23, 2004 | 04:16 PM
fret's Avatar
Anyone know what may be causing me to fail with high CO? passing is below 1%, my 83 tested at 3% at the 2500rpm test. Oh on a califonia dyno test.
TIA
Old Aug 23, 2004 | 10:28 PM
Rx-7Doctor's Avatar
What are the hc numbers like? rx7doctor
Old Aug 23, 2004 | 11:29 PM
fret's Avatar
This was the 2nd time failing, the 1st time #'s looked like this.
-------------hc(max)--------co(max)---------no(max)
15mph----297(152)------2.27(1.05)------104(1191)
25mph----262(123)------2.23(0.85)------91(1021)
2nd time around I didn't get a print out, tech only pointed out CO being too high, 3.00 at 25mph. I changed sparkplugs, air filter, plug wires and fuel filter before the 2nd attempt.
thanks.
Old Aug 23, 2004 | 11:36 PM
LinuxHead's Avatar
Slayer of Apex Seals
Not to restate the obvious, but did you make sure the cat was good and hot?
I failed 5 times in SF before figuring this out.
Old Aug 23, 2004 | 11:44 PM
fret's Avatar
Yes, I went for a nice drive before hand.
Old Aug 24, 2004 | 03:04 AM
Rx-7Doctor's Avatar
High C/o
Check To Make Sure The Air Exhaust Check Valve Is Not Allowing Exhasut To Come Back Into The Intake. Take It Off And Feel For Air, It Should Only Be Going Toward The Cat. Also Take It Into A Muffler Shop And Make Sure
The Cat Is Lighting Off, Means The Outlet Temp Should Ba Alot Higher Than The Inlet. 98% Of The Time I Have Put A New Cat On And Passed. Rx7doctor
RedBaronII
Sep 20, 2015 11:29 AM
Erosangel
Sep 18, 2015 04:06 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
