Sponsored by: CARiD
HELP, oil leak...Cant find it
Old Aug 22, 2004 | 04:30 PM
brokefd3s's Avatar
Recently had my fd rebuilt and for some reason it has just started leaking oil. I cant tell if its leaking all the time, but you can really tell when the car is parked. Its leaking on the drivers side of the motor towards the back, i thought it was the oil pan, so i had a new gasket installed on it.. That wasnt it, is there any where else it can be leaking ? Why can i only tell its leaking when its turned off ? It dosent look like its blowing oil back onto the tranny or the undercarrage of the car.. Please can someone give me some guidence
Old Aug 22, 2004 | 05:43 PM
Rotarded's Avatar
"Challenged" since 1993
You have several possibilities on the drivers side. From the top, your oil filter housing, oil pressure sensor, and the oil cooler banjo bolt/fitting. Best bet it to clean the area thoroughly with carb or brake clean, put a light above the oil filter housing, start the car, and look from underneath.
Old Sep 1, 2004 | 08:39 PM
fd3s_rx7's Avatar
did you installed the oil pan gasket yourself??
or did you have somebody else installed it for you??
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
BLK 93
Aug 19, 2015 03:47 AM
