turbo manifold for 12a
Old Aug 22, 2004 | 01:39 PM
BIG J MIXALOT's Avatar
SHSHSHA POCKET SAND
Question turbo manifold for 12a
does anyone know where i can get one for my 12a
Old Aug 22, 2004 | 09:53 PM
CarlRx7's Avatar
just go out and grab a 13bt manifold from a turbo fc 86-91. match it to a 12a flange and grind the holes inwards 5mm each and port out the exhaust ports a little.
dont even think about using a file like me. it took about 4 hours , 1 ea hole to file them out 90%, my dad came home and found his dremel. it cut into the cast like a hot knife threw butter.
then throw a gasket inbetween the two and bolt it on the engine. this will give you plenty of room so the turbo doesn't kit the intake manifold or the idler arm.
here are some pics of my manifold that i wallowed out and the turbo. 91 j-spec
carl
p.s. you might need longer exhaust studs. easy fix.
Attached Thumbnails turbo manifold for 12a-im002979.jpg   turbo manifold for 12a-im002973.jpg   turbo manifold for 12a-im002981.jpg
Old Aug 22, 2004 | 09:57 PM
RotaryRyan's Avatar
DSM
hey big j, is that carl in your avatar? he likes mustard and biscuits.
Old Aug 23, 2004 | 12:00 PM
Whitewidebodyrx7's Avatar
Steer with the Rear
i know a guy here in town that is a tig welder and he made a pretty sweet one a few years back...as i recall he still has it
Old Aug 23, 2004 | 12:18 PM
The Wankler's Avatar
FKITALL
Call Robert at Rotaryshack.com... He can help you there.
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
