AWS solwnoid
Old Nov 21, 2001 | 08:21 PM
RussellTT94's Avatar
AWS solwnoid
can anybody tell me exactly where the electrical connector for the AWS is? i know that it's on the passenger side of the engine bay, but i'm not sure exactly which wire it is. there's a connector then a wire that leads to the o2 sensor, but i dont think that this is it. there is another wire that goes directly under the UIM, is this one it? I talked to Jason, and he said it was one of these two, but i'm not sure which one. thanks guys, Russell
Old Nov 21, 2001 | 10:02 PM
spooledUP7's Avatar
There and back again
Two ways to get to it.
a. follow the 1" hose from the plastic intake elbow (Connects to the AWZ) or..
b. Draw a straight line pointing down from the double throttle actuator.
Any way you look at it, it is a bit tight for large hands to move around, but the harness can be unplugged and plugged back in without taking off the throttle body.
Old Nov 22, 2001 | 02:46 AM
Magnificent 7's Avatar
Won't you have trouble code (check engine light) come on if you disconnect the solenoid? I just made a block off plate for mine, and kept everything looking stock. However I still get a cold engine rev to about 2000 rpm until warm up is complete. It doesn't bother me, I just thought it would idle at 800 rpm cold after I disabled the AWS system. Anyone care to comment?
mazdaverx713b
19
Aug 29, 2015 12:30 PM
rotor_veux
Aug 23, 2015 09:06 PM
