Clutch Pedal Switch Bad?
Old Nov 21, 2001 | 12:08 PM
takerwolf's Avatar
Is the car supposed to be able to start in neutral without pushing the clutch in? Is there anything else the clutch switch is used for?
Old Nov 21, 2001 | 12:10 PM
13BAce's Avatar
On a long vacation
No, if you want to start the car the clutch pedal has to be held down. If you want to bypass this system just connect the 2 wires that go into the switch.
Old Nov 21, 2001 | 12:11 PM
SureShot's Avatar
Seduced by the DARK SIDE
Start interlock - That's it..
Old Nov 21, 2001 | 12:12 PM
Audiofight's Avatar
No. From my experience, which I just went through all this, is that you can't start the car in neutral without pushing in the clutch. At least, you aren't supposed to be able to.
If the car won't start either way, check that the switches are good. Just unplug them and put a jumper in. Or, go underneath the car near the starter and check that connection first, being it is actually easier in my view to get to.
My connection from the switch to the starter had gotten overly corroded and stopped my starter or selinoid from clicking because it was acting like the clutch wasn't pushed in. Cleaned the connection, and everything is better.
Old Nov 21, 2001 | 12:13 PM
1FastT2's Avatar
Thats the way I have mine rigged, works great.
Old Nov 21, 2001 | 12:29 PM
takerwolf's Avatar
Mine starts without using it, found that out by accident. So it won't affect anything else? (for example it doesn't doing anything to the idle when you push the clutch in?)
Old Nov 21, 2001 | 10:59 PM
13BAce's Avatar
On a long vacation
My friend did that too. I kind of like having the safety switch just in case the exhaust fumes cause me to forget that my car is in gear.
Old Nov 21, 2001 | 11:00 PM
13BAce's Avatar
On a long vacation
Nope, you should be fine.
Old Nov 21, 2001 | 11:09 PM
hypntyz7's Avatar
I have run across some 86 and early 87 cars that did not have a switch. I have an 86 gxl in my driveway right now that I start w/o pushing the clutch.
Old Nov 21, 2001 | 11:18 PM
Wargasm's Avatar
Weird Cat Man
Yeah my early 87 TII has always started without pushing in the clutch... I've never looked into WHY.. I don't really care!
Brian
87 TII
93 R1
Project88Turbo
Aug 29, 2015 02:23 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
