No boost after everything is warm?
Old Aug 16, 2004 | 12:47 PM
cooljerk187's Avatar
Hey guys, i have come across the problem of low boost after around 30 minutes of driving... I start the car up... and after 4000, i only have 4lbs. of boost... this cannot be controlled up or down by the boost controller. Then after a good 30 minutes of driving, the boost wont go any higher than 1 psi... What do u guys think could be wrong? The only modification i have is the non-sequential turbo mod, boost controller on the stock exhaust. I am also sitting with a broken air pump, which i dont think could be the problem. Rubber couplers after getting hot maybe? Leaky gasket? I dont know, Im stumped. Any help or advice is appreciated.
Old Aug 16, 2004 | 12:54 PM
seanfd3s's Avatar
airplane apex seals
you check for a vacuum leak
Old Aug 16, 2004 | 01:19 PM
yes i did, and i have none.... a vacuum leak would always be there, not only when its warm
Old Aug 16, 2004 | 01:23 PM
Toadman's Avatar
Nomad Mod
Not always true. Cold can seal a rubber split. Heat and psi once warm can crack it open.
Old Aug 16, 2004 | 01:53 PM
cruiser's Avatar
There was also a thread about a solenoid not working when it heated up (or was it the check valve?)
rgordon1979
40
Mar 15, 2022 12:04 PM
Bauer778
Nov 4, 2015 04:42 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
vmerino
Sep 5, 2015 11:26 AM
