Sponsored by: CARiD
New car, need help
Old Aug 14, 2004 | 05:09 PM
FCman's Avatar
New car, need help
Hey guys, I just bought an 87 rx7 with 131k, it is idling at 1500rpm and its backfiring. What's the problem and how do i fix it?
Old Aug 14, 2004 | 08:24 PM
rotoboy661's Avatar
vac leak
cheak all vac lines
Old Aug 14, 2004 | 10:29 PM
FCman's Avatar
will do
Old Aug 15, 2004 | 08:39 PM
DerangedHermit's Avatar
Like he said. The most common problem with our cars that affects idle is vacuum leaks. Instead of checking all the lines, I would just go ahead and get ALL new lines. After that many miles, it's needed. Get some nice silicone (except for gas lines) vacuum lines.
Since replacing all the vacuum lines will require taking off the UIM, go ahead and get a new gasket for the UIM/LIM connection. Gaskets are a great place to spring a hard to detect vacuum leak.
After doing all the vacuum related fixes, adjust your TPS.
Edit: Btw, that new gasket is like $4 from http://www.mazdatrix.com .
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Junkee
Aug 15, 2015 01:57 PM
