HKS wastegate 40mm and 50mm inlet flange size ?
Old Aug 14, 2004 | 03:04 PM
sub-zero's Avatar
Does the stadard HKS wastgate (40)mm have the same bolt pattern as the 50 mm? My 40mm is creeping at high RPM and My AVCR is set at 20 for duty so the combo is not working well at holding 20 PSI. Will the 50 bolt right on to my mani? If it does not I think I will go for a big Tial if I have to do cutting.
Thanks
Steve
Old Aug 16, 2004 | 02:20 PM
sub-zero's Avatar
Old Aug 16, 2004 | 03:49 PM
XSTransAm's Avatar
Ee / Cpe
the inlet flange is the same for the 40 and 50 mm hks gates...
the outlet is different however. the 40 is a 2 bolt oval flange and the 50 is a 4 bolt square.
Old Aug 17, 2004 | 10:28 AM
sub-zero's Avatar
Thanks. The outlet is open so it wont matter.
Old Aug 17, 2004 | 01:21 PM
RETed's Avatar
Who was the the one claiming the 40mm HKS was enough?
-Ted
Old Aug 17, 2004 | 04:14 PM
sub-zero's Avatar
enough? Not sure what you mean.
Old Aug 17, 2004 | 05:05 PM
RX7WEEE's Avatar
Need a 20b FD.
I think that he means that someone said that a 40mm waste gate would be big enough, but it seems as if it isn't.
Old Aug 19, 2004 | 08:33 AM
XSTransAm's Avatar
Ee / Cpe
my hks 40 is enough to keep my t61 at 7psi.
Old Aug 19, 2004 | 10:03 AM
Matlock's Avatar
It wasn't enough to keep my T4s at 15psi. God damn thing. The ol' bigger is better definetly applies here. Get the 50mm.
BTW the outlet on the 40mm HKS is in actually 36mm. Unlike the 50mm which is actually 50mm all round. It's a superior wastegate in my opinion, from personal experience with creep issues.
Although the 40mm does seem to work for some, it did not for me.
Old Aug 19, 2004 | 10:18 AM
XSTransAm's Avatar
Ee / Cpe
what manifold were you using?
Old Aug 19, 2004 | 10:24 AM
Matlock's Avatar
HKS cast on an FC. Likely part of the problem for sure. With a nicely designed tubular I can see the 40mm working. That was my experience anyway. May not be everyone's.
Old Aug 19, 2004 | 10:30 AM
XSTransAm's Avatar
Ee / Cpe
ive got the hks cast on mine, were you dumping to atmosphere or back into the exhaust?
Old Aug 19, 2004 | 10:39 AM
Matlock's Avatar
Atmosphere first, same problem, then I added a dump tube (~8in long) same results. Simply it could not handle it. I can't even remember how much testing and fiddiling I did. I thought for sure the 40mm was enough, but at higher revs 5,500 + the boost was climbing very quickly. Boost controller was fine, I really noticed the creeping when I went to the FMIC. I think it made the engine & turbo that much more effecient and it couldn't keep up. Dunno.
Where are my manners stealling a thread. The 50mm should bolt up to the manifold sub-zero. The inlet is similiar. It's the outlet's that are different between the two.
Old Aug 20, 2004 | 11:22 PM
elwood's Avatar
I'm about to install a cast HKS FC manifold, and this is good info. Will the 40mm TiAL bolt up? Will it flow better than the 40mm HKS? I've heard good things about them, and they're a little cheaper than the HKS gates.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
