Sponsored by: CARiD
starting problem help please
Old Aug 14, 2004 | 02:52 AM
ravensguildassasin's Avatar
never buy from family
hello all i just bought a 1985 rx7with a 12a motor. turned the key and got nothing but a klick!!!! had the starter checked running like a champ. checked the connection at the battery it was. bad replaced the connection. it started ran for a few minets died tryed to start it again and im back to a dead klick. im out of ideas but this is the first car ive worked on by myself and i hope you all can help me . thanks.
Old Aug 14, 2004 | 05:51 PM
well i got the car to turn over. started for awhile died. tryed to start it again tuned over but would not fire.any ideas
Old Aug 14, 2004 | 08:26 PM
rotoboy661's Avatar
check spark plugs,plug wires, distributor & rotor
clogged fuel filter??
is it getting fuel??
Old Aug 15, 2004 | 08:41 PM
DerangedHermit's Avatar
Your motor needs 3 things to run. Air, fuel, and spark. Check all the things involved with those 3 and you'll be good to go.
Old Aug 17, 2004 | 05:21 AM
TruSlyd's Avatar
SHORT!!!
Mine was doin that for a cpl days, and I went through and tested all the wires, and found a grounding wire (duno what it was) but I fixed it and its all better...
But wait... Mine never fully started... it just cranked over, started and died.
i ALSO HIT THE BATTERY WITH A HAMMER....... AND THEN IT WORKED... SO IUNNO :P
Old Aug 18, 2004 | 01:28 AM
well im a morron or my frend that was helping me was i dunno. but on the starter when i put it back on i put the hot wire on the wrong side. it starts the first time i try runs but cant get it to start again ? but it turns over just wont start again
Old Aug 19, 2004 | 07:01 AM
TruSlyd's Avatar
Well can you push start a rotary?? Cause I tried my damndest to do it hte other day and... NO LUCK.. JUST CHURNING SOUNDS... And I know how to push start a car for those who wanna make wisecracks :P
Anyways, if its the starter you'd be able to push start it... And it would run!... If not then... Something else man.
Old Aug 19, 2004 | 04:49 PM
Yes, you can push start them as far as I know. You might have to disable the clutch switch which completes a circuit when the clutch is depressed that allows you to start the car.
Old Aug 20, 2004 | 03:08 AM
TruSlyd's Avatar
My clutch switch is disabled... And we tried again today to push start it.... And mine wont... It starts fine, I just had to see if we could do it... And like I said b4, I know how to push start cars.
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
