Haltech Maps?????3.5 - 4k falling on its face
Old Aug 12, 2004 | 11:42 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
OK..
I got the car idling perfect, the BAC working correctly for cold starts, it revs fine and takes off fine...
However, when i get to 3.5K it falls on its face.... even if you are babying it not on boost. I'm thinking its the injector staging/ fuel maps that are screwing things up.
I have the HitMan's basemap for a Tii with 1600's in the haltech. It'll rev smoothly past 4.5k, its only when you are driving that it falls on its face and breaks up
I can't get the wideband in it cause there are two freaking hurricanes comming and its pouring here in PA and I'm still working on my hoodscoop... SOO
Anybody care to share their timing and fuel maps for an s4 with 550's and 1600's and a ported motor. (I have a BNR stageIII turbo and FMIC if anybody has that combo) so i can take a peak and see if the maps are really off, until i can get the wideband on the car?
Old Aug 13, 2004 | 04:11 PM
Carl Byck's Avatar
Mad Man
I have a map that worked PERFECT for my car, but with 850/1600, on a mild street port and a .81 p trim TO4S, the map is good to 30psi (don't ask how I know that ). Your welcome to the map. This map is unrelated to my problems, which I think are probably mechanical, and or related to me "fixing my map" I'll send you the pre-fixed version LMK. If I post it here, can you use it? If so, how would I go about posting it, or I can send it in an Email. Carl
Old Aug 13, 2004 | 11:12 PM
RETed's Avatar
Um, you can't confirm that???
How are you tuning?
By yourself? Learn to use the CTRL-D datalog!
If you have someone else at the laptop, tell them to keep hitting HOME.
-Ted
Old Aug 14, 2004 | 03:33 PM
got it Fixed... was way to lean....
now need e6k V 634U to datalog with A/F's any body got it???
mulcryant
Oct 4, 2015 12:18 AM
rotor_veux
Sep 28, 2015 09:25 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
