Sponsored by: CARiD
engine heating problems
Old Aug 11, 2004 | 04:23 PM
leon's Avatar
Newbie
Exclamation engine heating problems
i have a 92 rx7, after 10min my engine is so hot that the water in the radiator and engine boils, although my heating gauge reads normal.
is this normal or do i have a serious problem.
if this is a problem has anyone else had it and if so what did u do to fix it.
please let me no.
thanks leon.
Old Aug 11, 2004 | 05:20 PM
racer1's Avatar
flying apex seal
Check if your fans are working. If they are not, check for a burned fuse.
What do you mean boils? It's supposed to boil.
Old Aug 11, 2004 | 05:23 PM
Syonyk's Avatar
Thermostat, radiator caps, fans. Any of those acting up can cause the problems you're having.
Alternately, you can have the same effect (boiling looking water) if a coolant seal is blown and exhaust gasses are getting into the coolant.
-=Russ=-
Old Aug 11, 2004 | 06:26 PM
Tom93R1's Avatar
gross polluter
Is this 10 minutes at idle or when driving? 10 minutes of idle shouldnt get anything that hot, but if it does definately check the fans to make sure they are turning on and check the coolant caps to make sure they seal. 10 minutes of driving I would be more inclined to look at the thermostat not opening and once again check the caps for leaks.
If it looks or sounds like it is boiling but maybe it really isnt then it is probably a bad coolant seal.
Old Aug 12, 2004 | 02:23 PM
drcoopster's Avatar
Buy my car.
Mazda didn't make a '92 model RX-7, they continued to sell the '91. So you have a S5, I assume -- not that it makes a difference in this case. Test your thermostat per the FSM, but it sounds more like a coolant seal problem.
Old Aug 12, 2004 | 02:38 PM
TruSlyd's Avatar
Where do you check the coolant seal???
Mines having the same troubles... Cept my thermostat is taken out. and no leaks.
gtcd
30
Aug 19, 2015 02:44 AM
befarrer
Aug 14, 2015 04:18 PM
