RPM's Drop To Almost 0....
Old Aug 9, 2004 | 10:40 PM
Hello I currently own a 93 mazda rx7.
When the car is in neutral and I rev to about 3k the rpms drop down to almost 0 and then goes back to normal idle point....
Anyone know why the car could be causing this?
Regards,
WB123
Old Aug 10, 2004 | 12:01 AM
Tom93R1's Avatar
gross polluter
do you have stock ECU?
Might check the dashpot, unless you have PowerFC then there are settings that can fix it.
Old Aug 10, 2004 | 12:06 AM
Bamont's Avatar
Billy Bo Jangles
Hmm..
Come to think of it, my 93 RX7 had the exact same problem. I found out that when I bought the car, it didn't have a catalytic converter on it, and was therefore running fairly lean. Ergo, I opted to snag a tuner and it fixed my idling problem.
Old Aug 10, 2004 | 12:34 AM
MrRx's Avatar
Rotary on a budget
Another possible cause would be your Idle control screw in the TB, or the ICS (idle control) under the upper plentium.
Old Aug 10, 2004 | 05:39 AM
blacksupra94's Avatar
Gone domestic
My car has done the same thing for a while. A lot of people said its not a big deal.
Old Aug 10, 2004 | 09:45 AM
Tom93R1's Avatar
gross polluter
Oh yeah, is your air pump still on? I disconnected mine for something when I had the stock ECU and that caused alot of similar problems.
Old Aug 10, 2004 | 10:43 AM
Kento's Avatar
2/4 wheel cornering fiend
If your engine is totally stock, I'd check dashpot operation first. You may have to do some slight adjustment of the air bleed screw (do a search, there's a couple of threads that have a photo of its location) or the idle adjustment screw.
alexdimen
20
Oct 23, 2015 01:50 PM
The1Sun
Sep 18, 2015 07:13 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
firzen
Sep 15, 2015 12:04 PM
gabescanlon
Sep 5, 2015 12:09 AM
