Power FC different boost settings with the PFC...
Old Nov 19, 2001 | 09:35 PM
JoeD's Avatar
when you get a PFC tuned, does it have different maps for different boost levels?? for example, if its tuned for 12 PSI, and you wanna up it to 14 for the occasional Supra/Corvette whooping, will it run the same fuel/timing map as 12 PSI. does that mean that you will run leaner at 14 PSI than 12 PSI, or is there a separate fuel/timing map for each individual level of boost??
TIA.
Old Nov 22, 2001 | 11:06 AM
Johnny's Avatar
OG
didn't I just answer this....weird.
anyways tune it for the higher of the 2...it will adjust if you run less...
Jun 26, 2016 10:21 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
