1-rotor from 13b
Old Aug 4, 2004 | 12:46 AM
drcoopster's Avatar
Buy my car.
1-rotor from 13b
Could you mate together the front housing, one rotor housing, and the rear housing from a 13b and make a 1-rotor engine? You'd obviously need a custom eccentric shaft and counterweights. What else would you need? Would the water pump just work? A custom oil pan would probably need to be made. I guess I should go make friends with some of the Mech-E's around here.
Just toying around ... could make a sweet go-kart.
--Ian
Old Aug 4, 2004 | 09:59 AM
Tom93R1's Avatar
gross polluter
The Atkins Rotary lawn mower is a single rotor from a 13b so yes, it can be done. How much work who knows, but I think you are probably pretty close with your guess of what needs done.
Old Aug 4, 2004 | 11:32 AM
Jeff20B's Avatar
Lapping = Fapping
All I need for my single rotor 13B is a short E shaft, short tension bolt set (Atkins sells these items), a gasket set and some sort of intake setup. Oh, I suppose I need three apex seals too.
Old Aug 5, 2004 | 07:43 AM
drcoopster's Avatar
Buy my car.
You have a 1-rotor oil pan? Or is no modification needed?
Old Aug 5, 2004 | 11:42 AM
Jeff20B's Avatar
Lapping = Fapping
I wish.
Old Aug 5, 2004 | 03:25 PM
Tom93R1's Avatar
gross polluter
I imagine it would almost be easier to set up some kind of dry sump system than to make a new pan. Well, maybe not, but I bet it wouldnt be that much more work.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
