What the hell dose this thing do..pic inside(inside secondary injector holes)
Old Nov 18, 2001 | 10:46 PM
Bacon's Avatar
IRS 4 Life
ok well i intallled my 2krd rail and 1600 bosch injectors, and during the instilation you had to remove these things.
..what do they do? help in fuel atomisation? just wonderin, im guessin i dont need them any more???
Old Nov 18, 2001 | 11:21 PM
DK's Avatar
DK
40k worth of fail
Len ... I don't see what you're talking about, but based on your description are you talking about the long black plastic inserts with the mesh screens at the end? Then your guess is as good as mine -- the screens aid in atomizing the fuel.
Old Nov 18, 2001 | 11:40 PM
Bacon's Avatar
IRS 4 Life
wierd, spraying a fine mist of fuel on a mesh screen to aid in atomisation....almost makes me wonder what these engineeres were thinkin sometimes, but they have to know what they were doin....right?..i think ill add this to my list of mazda "acomplishments"so that makes
ast,
84 vac lines
cheapo rad
wierd mesh thingies in 2ndary injector holes
Old Nov 19, 2001 | 12:10 AM
spooledUP7's Avatar
There and back again
You forgot the two "Open" lids above the tail lights that lead to absolutely nothing.
Old Nov 19, 2001 | 08:15 AM
Poweraxel's Avatar
Re: What the hell dose this thing do..pic inside(inside secondary injector holes)
those plastic things are the "air bleed sockets" they help guide the fuel charge down the port instead against the wall of the port. since your using the k2rd rail you can remove it. BTW: make sure you tighten down the rail to the holding bracket firmly! "Maestrul's" rail got loose over time
Old Nov 19, 2001 | 10:48 AM
BCNU's Avatar
Actually...
Bacon-
While they are air bleed sockets as PowerAxel said, I've been led to believe that they do aid in atomizing fuel, but the injectors do not spray a fine mist, but a steady stream... just a head's up man!
Jason
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
