Sponsored by: CARiD
Oil leak Help Please!!
Old Aug 1, 2004 | 05:36 PM
MrZUMZUM's Avatar
Below- "Esses" at RA
Just got off the track at Sebring............and I need some oil leak HELP!!!
I've got some type of leak occuring on my FD, especially when tracking it. After a session I've got quite a bit of smoke coming from under my hood, and the entire area on the passenger side is an oily mess. In other words, the entire area in the neighborhood of the oil filter, and obviously the oil is all over the hot engine causing the smoke. After the car sits for a bit I'd easily say there's 5 tablespoons or so collected under the car.
There was a guy there that is a rotary mechanic and he took one look and said, "Yep, I've seen that a lot". It's caused by the oil sloshing around and it's coming out the overflow tubes in the filler neck area. I really can't figure where those tubes are (can't see 'em) and if that even makes sense. He said, "After your car gets about 3/4 of a quart low it'll stop." Well, it pretty much did. But then as I was leaving today I added about 2/3 of a quart to make the drive home, which was about 1 1/2 hours and just typical highway stuff; no high g turns, and when I got home I once again had some smoke from under the hood. It's almost like I've got some back pressure forcing oil up and out somewhere relatively high on the engine for it to be all over that area around the oil filter, including slightly higher than the filter itself.
One other factor is that this engine is newly rebuilt and I never expienced this before the rebuild. Obviously my guy is good for it but he can't find the leak as of yet either.
Thanks in advance.
David
rotor_veux
Sep 3, 2015 07:10 PM
sypath
Aug 16, 2015 12:06 AM
