Power FC Air Flow Question
Old Jul 30, 2004 | 04:44 PM
XxJMF02xX's Avatar
Racer
Air Flow Question
How much airflow can an untuned PFC handle?
Old Jul 30, 2004 | 05:10 PM
cewrx7r1's Avatar
Eye In The Sky
Try converting about 280 hp to CFM.
Old Jul 31, 2004 | 06:19 AM
XxJMF02xX's Avatar
Racer
280hp? Is that it? I was expecting more.
Old Jul 31, 2004 | 08:48 PM
cewrx7r1's Avatar
Eye In The Sky
We are talking RWHP and you said untuned PFC which I would take as stock maps! You would run it on a stock engine or lightly modded engine. Such a engine you should not run past about 11PSI for safety. At 12psi about 300RWHP.
Old Aug 1, 2004 | 06:21 AM
XxJMF02xX's Avatar
Racer
My car is lightly modded so far only a downpipe and intake. Next is the cat-back, wastegate and vaccuum hoses (both for reliabilty), then fuel injectors and intercooler. I won't up the boost until I rebuild (and port) the engine. I was wondering if the pfc could handle all that and more untill I get it tuned.
Old Aug 1, 2004 | 04:12 PM
cewrx7r1's Avatar
Eye In The Sky
Many say the stock maps can handle about three small mods but not MP.
If you go Intake, DP, and catback that is about it. Now we are talking mods that increase air flow. A larger IC does not increase air flow.
Old Aug 2, 2004 | 08:52 AM
XxJMF02xX's Avatar
Racer
I thought the three small mods was for the stock computer not the APEXi pfc
Old Aug 2, 2004 | 12:14 PM
RotorJoe's Avatar
Hooray For Boobies!!!
The untuned PFC runs off the stock maps. That is why you can not gove over the three mod rule. Once you tune the PFC that rule can be broken.
Old Aug 2, 2004 | 03:43 PM
Tim Benton's Avatar
FD title holder since 94
how are you going to do the wastegate as a reliability mod? External wastegate on the stock twins?
Tim
Old Aug 2, 2004 | 04:36 PM
XxJMF02xX's Avatar
Racer
You can port the stock wastegate.
Old Aug 2, 2004 | 09:44 PM
Tim Benton's Avatar
okay, I was just wondering what you actually meant. Before you pay someone to do it, check to see if you have creep first. Mine doesnt' creep and I have all the mods (resonated MP).
Tim
Old Aug 3, 2004 | 07:44 AM
XxJMF02xX's Avatar
Racer
I was goin to do it myself anyway since its not especially sensitive. I'll just make sure the bore is smooth and all shavings are removed before reinstalling it.
Old Aug 3, 2004 | 07:51 AM
XxJMF02xX's Avatar
Racer
Actually a larger IC even without better piping can improve air flow. Thats the boost drop off or boost loss factor you read about if you compare IC's. The restriction in airflow caused by an IC can cause a pressure difference between the pipes(or manifold) after the IC and the pipes before the IC. But whats more important than the air flow is that the air will be cooler thus more dense and will require more fuel.
Old Aug 3, 2004 | 10:36 PM
cewrx7r1's Avatar
Eye In The Sky
True, a larger IC might have less boost drop across it.
But; at a set PSI boost read at the LIM or UIM, the flow is the same. The difffernce is how hard the turbos have to work to produce the same boost.
As far as air temperature goes, small IC will cool just as well as a large IC in winter.
So what mods improve air flow regardless of outside temperatures?
Old Aug 4, 2004 | 01:50 AM
XxJMF02xX's Avatar
Racer
I live in southeast Texas. We don't have winter. Winter for us is 68 degrees. Summer is 100 degrees with 99% humidity.
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
12abridgeport
Aug 17, 2015 06:28 PM
