car not starting
Old Jul 29, 2004 | 05:22 PM
Forgie's Avatar
car not starting
ok......a few weeks back we had a massive downpour of rain. while driving home from work my car hit a puddle and the nose went compleatly underwater. the car stalled out and hasn't started since.
I have removed the airbox, it was full of water. I pulled the plugs out and cleaned them, let the engine dry out. weeks later the car still will not start. it just spins forever but wont turn over. is there something I should be looking at?
Old Jul 29, 2004 | 05:50 PM
Kentetsu's Avatar
Have you dried out the cap and rotor, or the plug/coil wires? Also, check any electrical plugs that might have retained water. Might be someplace to start...
Old Jul 29, 2004 | 05:52 PM
Kentetsu's Avatar
Oh, also, did you test wether or not you have spark at the plugs? That would narrow it down to a fuel issue, rather than ignition.
Old Jul 30, 2004 | 04:51 AM
slashdawg00110's Avatar
RTFFAQ
Don't know if you've seen this, but it has many things you can try.
https://www.rx7club.com/showthread.p...hreadid=162062
Here's another good link
http://www.mazspeed.com/diagnosingdr...typroblems.htm
HTH
Old Jul 30, 2004 | 11:54 AM
Rx7carl's Avatar
Airflow is my life
If you got that much water in the engine I suggest you change the oil. Also crank the engine around by hand with the plugs out to get out any water. Once its all good and dry and with fresh oil. Then put a tablespoon of oil down each primary carb throat to give a compression boost, then try and start it. Oh and I assume you checked the ignition system? It is working right? You have removed the cap and rotor and dried it all out?
Old Jul 30, 2004 | 12:04 PM
RTFFAQ
Or you can squirt some oil (or MMO) into the plug holes as long as you have the plugs out. I've wondered how effective it is to spill a bit of oil down the carb when it has to make its way through the carb and down the intake runners. How much actually makes it into the engine?
Old Jul 30, 2004 | 03:43 PM
Lee Lyons's Avatar
With the amount of water that sounds like went into your car you could be looking at some fried circuits...with that much water you could have just as simply blown a couple of fuses. Check your fuse box.
Old Jul 30, 2004 | 08:15 PM
Forgie's Avatar
alright......fuses look fine. I bought a MSD 6A and 3 new coils and new wires and plugs. so hopefully that will fix the problem(if spark is the problem). the starter doesn't seem to be engageing, it just makes a clicking noise and doesn't turn the engine. so I think I may need a new starter aswell.
Old Jul 30, 2004 | 09:24 PM
GavinJuice's Avatar
Leave A Message
Your still haven't told us if you have spark, fuel, compression. I don't see a point at throwing parts at a car when you don't even know the problem. The MSD is a nice upgrade though.
Old Jul 31, 2004 | 08:52 PM
Rx-7Doctor's Avatar
No start
If you are still running the stock injection system and have the air-flow meter, there is a good chance the water got into the air-flow meter and back-fired. This
would cause the flap door on the meter to warp causing a no fuel situation. The
first thing as others have mentioned is whether you have no spark or a no fuel situation and then go from there. Good luck and let us know what you find.
Kyo
Apr 13, 2019 09:24 AM
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
ashleymiche
Aug 14, 2015 12:59 PM
