removing the emissions parts
Old Jul 28, 2004 | 05:02 PM
rx7jake's Avatar
blah
Question removing the emissions parts
i've got an 87 non-turbo that i just bought off a friend.he tells me to take the air pump out, no worrys. but it has that DO NOT REMOVE sticker that has me worried.
ive got a full race exhaust from corksport so the long tube that goes to the cat has no home. so can i remove that to? if so what about the lines, hoses going to the motor from said parts do i run them so they just dump under the car er what? any info would be better than my haines manual on the subject. thank you.
Old Jul 28, 2004 | 08:02 PM
PureSephiroth's Avatar
#1 Certified Cone Killer
the do not remove sticker is on there because removing it is in violation of federal emissions standards. For the rest of your troubles do a search on "emissions removal" or something similar. You will find a number of lengthy threads detailing exactly what you can and cannot remove and how to remove what you are able to.
Old Jul 29, 2004 | 04:30 PM
rx7jake's Avatar
blah
ok ill give it a shot thanks
Old Jul 29, 2004 | 05:06 PM
rx7jake's Avatar
blah
this helps with the air pump http://www.rx7.org/Robinette/air_pump.htm but did anyone ever think about routing it to the intake? i know the that site says the air pump disengages under full throttle but that can be changed. what do you think?
streetlegal?
Mar 17, 2022 02:46 PM
cdn
14
Sep 10, 2015 06:23 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
