need injector answer FAST
Old Jul 28, 2004 | 04:36 PM
DEZERTE's Avatar
777** The Anti-rice
can you interchange
88 13b T high square offset 550cc purple 195500-1370
89-91 13B NT high oval center 460cc red 195500-2010
if you swap the plug? What im saying, is the other difference the plug shape?
Old Jul 28, 2004 | 04:52 PM
version13's Avatar
Exhaust leak
The harnesses will not fit into eachother, but the resistance is the same for both of them.
Old Jul 28, 2004 | 06:52 PM
ddub's Avatar
i am legendary
Originally Posted by DEZERTE
can you interchange
I believe if you swap the plugs it'll be fine. You have oval, so you cut them off and splice in the square plugs. Should be the same since they are both high impedance, but I'm not 100% sure on this.
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
bryancmatthews
Power FC Forum
Sep 5, 2015 03:57 PM
