window trim
Old Jul 28, 2004 | 12:45 AM
88ROTARY's Avatar
window trim
do anyone know where can i get the outside window trim from( the part that rust out all the time)
Old Jul 28, 2004 | 12:47 AM
OC_'s Avatar
OC_
I'm bastardizing my car!
yes.. i want to know too. Mine is starting to look like crap
OC_'s Avatar
OC_
o look, 1000 posts
Old Jul 28, 2004 | 12:51 AM
fastrotaries's Avatar
W. TX chirpin Monkey
I'm gonna bead blast mine, and do some spray paint job, flat black. If i had money i would paint it, profesionally......The whole car that is.
Old Jul 28, 2004 | 12:54 AM
Sometimes you can find a pretty nice ones in junkyards.
Old Jul 28, 2004 | 12:56 AM
HeffBoost's Avatar
Keep Right Except to Pass
What about Mazdatrix? http://www.mazdatrix.com/DOORWIN2.HTM
Or Victoria British is sure to have them.
OC_'s Avatar
OC_
i would like a brad new one. Its just dumb how those rust through like that on the bottom ones, and how the top ones around the window just get all crappy.
Old Jul 28, 2004 | 01:05 AM
88ROTARY's Avatar
Smile
THANK YOU THANK YOU!!!!!!!!!!!
Old Jul 28, 2004 | 04:35 PM
J-Rat's Avatar
Alcohol Fueled!
I just pop them up. You run the window down, then you pry them up.
Then sand and paint them. Mine look brand new!
Old Jul 28, 2004 | 04:54 PM
croffeyc's Avatar
RLRR LRLL
Mazdatrix was cheaper for me than Victoria British, for what it's worth.
ck
Old Jul 28, 2004 | 05:53 PM
asherwood's Avatar
I got mine from the dealer, no offense to those who have painted them, but they are just not the same as brand new.
The biggest problem with replacing any exterior trim piece other then the cost is...once you get started by putting the first peice, it makes the other original parts look like @#$$% and then you want to spend more and get more...then the entire process repeats itself!
After all of this you will want to paint the car, get new wheels, etc, etc, etc! Now I am scared to add up the bills, probably spent more on parts then I have the entire car!
Consider yourself warned!
Old Jul 28, 2004 | 05:56 PM
JackoliciousLegs's Avatar
haiO
Plastidip does the job. Perfectly.
Old Jul 28, 2004 | 06:44 PM
Sir Rupert Hobo's Avatar
seven-less
haha! tru that playa!
plasi-dip is only found in napa(i think)
do a search. it's good stuff.
Old Jul 28, 2004 | 06:53 PM
MidnightOwl's Avatar
2 Rotors, 1 Turbo
Wow nice! Makes me happy to know I can put that infernal sand blaster to work!
Old Jul 28, 2004 | 06:58 PM
haiO
btw... i suck at all things paintlike, and that was my first try. I got mine at home depot. Diluted it with a little paint thinner... and painted it on in 3 coats. Took me 1 hour start to finish.
Old Jul 28, 2004 | 08:35 PM
nashman69g's Avatar
Boost Addict
the new Mazda OEM replacements are plastic instead of metal..no more rusting!
Old Jul 28, 2004 | 09:44 PM
asherwood's Avatar
Looks good! Do you have any pictures without the water?
Too late for me ( I dropped the bucks) but a friend with a 86 could use a makeover. Home depot you say? What was the brand name? Plastic dip?
Thanks
Coochas
44
Nov 5, 2019 11:08 PM
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
turbojeff
Oct 5, 2015 10:50 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
