Fuel pump and regulator Questions
Old Jul 27, 2004 | 12:31 AM
Fire85GSLSE's Avatar
Chad Carson
Thinking about upgrading the FP and adding a Reg. to my GSL-SE.
Those of you that have upgraded your fuel pump what brand did you use?
Likes / Dislikes
What about adding a pressure regulator with guage?
Brand, likes and dislikes?
What PSI are you running? FI? Carbs?
Thanks
Old Jul 27, 2004 | 03:42 AM
louved_gen1's Avatar
My fuel pressure regulator is set at 4.5 psi and it is perfect. Just the other day i kept my car in first pullin away from a stopsign and let the RPMs build up slowly to see how it feels. It was really smooth up to 7000rpm where i cruised at that for a couple seconds. No high end power fade with my setting. Intake setup in signature.
Old Jul 27, 2004 | 05:40 AM
Rex4Life's Avatar
RX-7 Alumni
Walbro 255 inline fuel pump. Installs just like a stock unit. For a stock GSL-SE the Walbro 190 lph pump wil do.
An aftermarket FPR is necessary for the 255. I used an Aeromotive A-1000-6. Runs 28.5 psi at idle.
No problems with either.
Scott
Rotospectre
Mar 28, 2018 03:33 PM
86glxNA
Aug 22, 2015 08:54 PM
