how hard is it to remove sunroof ?
Old Jul 26, 2004 | 08:34 PM
gentlejax2's Avatar
my parts car has a better panel than my driver just wrong color and the motor works as good. I was thinking about swapping so there will be no rust when I get it painted.
Mike Z
Old Jul 26, 2004 | 09:11 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
you can swap just the skins. Open the roof a few inches(~4-6) and pry off the inside cloth panel with a flat blade or a small prybar. It has maybe 4 snaps that have to come off. Once it is free of those it should slide forward easily and off it comes! Then its just a matter of unbolting the skin. IIRC it is 6 nuts/bolts that hold the skin on the rails. Repeat and reverse on your car.
Santiago
Old Jul 27, 2004 | 07:06 AM
gentlejax2's Avatar
thanks, I will check it out.
Old Jul 27, 2004 | 07:19 AM
SureShot's Avatar
Seduced by the DARK SIDE
The hardest part is not breaking the plastic headliner trim parts.
Th0m4s
Feb 26, 2019 02:04 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
