Rear wheel bounces on hard turns
Old Jul 26, 2004 | 07:26 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
I have a 1990 GXL. The right rear wheel feels like it is bouncing like crazy when taking fast turns. The whole car vibrates, and it seems to be coming from the right rear wheel. It doesnt happen on straight-aways, only on turns. Does anyone know what causes it? Thanks
Old Jul 26, 2004 | 07:28 PM
BlackLabel6542's Avatar
im having the same problem with my 88 GTU but my tires are hella bald so i think that has something to do with it :-)
Old Jul 26, 2004 | 07:40 PM
spot_skater's Avatar
The Cause of Death
this is a longshot but do you think you might've thrown a spring?
if there's a loud clunking too get it checked out, also the car would be lower on whatever side...
Old Jul 26, 2004 | 07:44 PM
nitroracer's Avatar
Dub'N
time to upgrade suspension!!!
Old Jul 26, 2004 | 08:45 PM
getbent69's Avatar
Check your shocks/Struts. When I 1st got my 7, the backend would come off the road while cornering, you could feel it bounce. Scared the hell out of me. My shocks were stuffed (you could compress them in your hands). Quick test is push down on the car above the shock and let it go, it'll either come backup and settle in a controlled manner or bounce up and down a few times (this is bad). If your still not sure drive it to a suspension place they'll probably figure it out in about a min flat.
Old Jul 26, 2004 | 08:55 PM
twistedriver's Avatar
Finally I have LSD
Maybe a broken toe bushing? Or a LSD that has no oil in it? (maybe it leak out) Just a thought
Old Jul 26, 2004 | 11:16 PM
BDentonFC's Avatar
It sounds like a wasted shock absorber. Upgrade time!
Old Jul 26, 2004 | 11:54 PM
RETed's Avatar
Bad rear shock(s)
Jack the car up and I bet one or both rear shocks are leaking.
Replace.
-Ted
Old Jul 27, 2004 | 07:47 AM
JKM's Avatar
JKM
Yeah, my car does the same thing but it's on both sides of the rear. I need new struts BADLY. One of these days...
ChrisRX8PR
Aug 21, 2015 01:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 17, 2015 09:36 AM
