why no fuel?
Old Jul 25, 2004 | 05:05 PM
cmjaure's Avatar
a.k.a. Mike
why no fuel?
Well I have 3 s4 na and this is the first time this has happend to me I just got this one and it was sitting in a garage for about 9 months now I have had a few flooding problems with another one but Im not sure what the problem is. I have replaced the mass airflow senser fuel pump and reg. checked all fuses and it is getting fuel to the rails but not out of the injectors. I think i might be a computer problem let me know what you think cause the only spare part i dont have is a computer. thank you
Old Jul 25, 2004 | 05:29 PM
stacher's Avatar
You say that fuel is getting to the rails. So we can assume the pump is woking.
I had a similar problem. I had replaced my fuel pump and the car ran for a while. Then it would not start. I disconected the fuel hose (the one that come from the fuel filter) at the rats nest and had no pressure. TRY THIS. If you have no pressure then: 1. the fuel pump is sucking air. The filter at the pump is clogged or 2. Your fuel filter is clogged.
If you have pressure check the regulator.
Old Jul 25, 2004 | 05:42 PM
cmjaure's Avatar
a.k.a. Mike
I have replaced all of that that is why I am thinking it is a computer problem and the car does have plenty of fuel pressure. any other things I might check. Thank you
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
