It won't start.... After Vacrac removal... Sob sob...
Old Jul 25, 2004 | 04:28 PM
Rotaryrockstar's Avatar
Epitrochoid Chamber FTW
Unhappy It won't start.... After Vacrac removal... Sob sob...
Well... Cleaned all injectors... New fuel lines... I plugged every remaining mysterious vacuum hole left hanging open...
Cranking and no start. I did pressurize the fuel system and found no leaks.. I could hear the fuel in running in there! That was neat...
So my question is, do I try the ATF start on it? With all the cranking did it flood it?
Or is there an other series of things I should look at first?
I was very thorough in the reassembly, I really don't know what it could be...
Thanx!
sob, sob...
Old Jul 25, 2004 | 04:33 PM
If the FPR solenoid was hooked up incorrectly, could it prevent ignition?
Old Jul 25, 2004 | 05:16 PM
Question
When I had my FPR solenoid hooked up exactly to this drawing, with the fuel system pressurizing I had gasoline coming out of the breather on the solenoid?
Any ideas? I know that's not right.
Attached Thumbnails It won't start.... After Vacrac removal... Sob sob...-vacrack2.jpg
squirrels
Sep 1, 2024 09:52 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
lnlreaper
Sep 27, 2015 09:59 AM
