FC Wheels and Bolt Patterns
Old Nov 17, 2001 | 08:59 AM
skotter's Avatar
Guys,
I know that most of you have gotten aftermarket wheels or done some sort of upgrade to your wheels. It has been brought to my attention that the bolt pattern is 5X114.5. Is this correct? If so has anyone made a list of other vehicles that have the same bolt pattern? It would help in my selection of wheel upgrades for my 1987 GXL.
Scott
Old Nov 17, 2001 | 09:01 AM
13BAce's Avatar
On a long vacation
Re: FC Wheels and Bolt Patterns
Originally posted by skotter
Guys,
Scott
It's actually 5x114.3. Supras and 300ZX's have the same bolt pattern, as well as alot of other Japanese cars. It's a pretty common bolt pattern.
Old Nov 17, 2001 | 02:04 PM
black7's Avatar
I also think the bbs vert wheels look good on other fcs. Just an idea.
Old Nov 17, 2001 | 02:28 PM
EL PAALO's Avatar
do you want aftermarket wheels or stock wheels from another car? the offset will be important too.
mr2 91-95
mark iii and iv supra (maybe the earlier ones too)
is300
current celica (don't know about the earlier ones)
97-01 prelude
300 z
3rd gen rx7
mustang
probe gt 93-97
3000 gt
eclipse
check here too wheelsize.com
Old Nov 17, 2001 | 04:49 PM
Scott 89t2's Avatar
SOLD THE RX-7!
you have to be carefull because alot have the same bolt pattern but won't fit due to the off set.
Old Nov 17, 2001 | 05:52 PM
13BAce's Avatar
On a long vacation
I have them on my 91 coupe, and it looks good.
Old Nov 17, 2001 | 09:32 PM
ROSHX7's Avatar
FYI, stock TII offset is +38mm. Prelude wheels are +55mm offset and Probe GT wheels are +40mm offset... that's all I know
Old Nov 18, 2001 | 01:09 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Yes they do. Let me elaborate on sources a bit though.
I've seen gold ones (otherwise identical) on Lexus SC300/400 models. Also, the Lincoln Town Car wheels. Not positive about the bolt pattern- the 5x114.3 IS a Ford bolt pattern, but I'm not sure if the big cars and small cars are the same pattern. If they are, those should fit, be easy to find, and pretty cheap. (I've seen them for about $85/each at a used wheel shop.)
Brad
Old Apr 16, 2004 | 01:20 AM
live2drive15's Avatar
Well if it was/is a Ford pattern that would make sense considering Ford owns a large part of Mazda. The Ford investment in Mazda was Extremely vital to the survival of the rotary projects.
