ignition coil
Old Jul 22, 2004 | 10:25 PM
Carner's Avatar
Lycanthropy
Question ignition coil
I want to change my stock ignition coils with new ones. what do you guys use? I want to keep the stock location.
Old Jul 22, 2004 | 10:32 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
There are several different brands available. I personally just use the stock Diamond coils, but that's because I'm cheap. As far as stock replacement sized coils go, you can get MSD, Jacobs, Crane, pretty much any brand name. I don't know that there is much difference between the brands...
Why do you want to switch your coils out? If they haven't gone bad, your money would be better spent elsewhere, IMHO.
Old Jul 22, 2004 | 10:36 PM
Siraniko's Avatar
RX for fun
FYI:
MSD came with 2 types of coils: MSD or stock ignition (MSD).
Old Jul 22, 2004 | 11:14 PM
Carner's Avatar
Lycanthropy
my coil are shot. i thought i heard that oil filled coils cant be placed on there side like the stock coils.
Old Jul 22, 2004 | 11:47 PM
Rx-7Doctor's Avatar
Ignition coils
Why do you think your coils are shot? Are you having a performance problem?
The stock diamond coils are sufficent for most applications. The jacobs coils are
also very good replacements, sell for about $45.00 each. Can also get used ones
from wrecking yard, they really don't fail very often.
Old Jul 23, 2004 | 12:06 AM
Carner's Avatar
Lycanthropy
ones split open
Old Jul 23, 2004 | 12:14 AM
Rx-7Doctor's Avatar
Coils
Well, that would definitely cause a problem. I had good luck with the jacobs ones. They don't drop off voltage wise thru the rpm range like most do. If it's in your
budget this would be a good way to go.
Old Jul 27, 2004 | 09:54 AM
Brianhsval's Avatar
I'm old but not slow
2nd gen coil conversion.
coil - 15 bucks @ junk yard
install - 15 - 20 min max. ( most of that time trying to figure out where to pu it.)
Gain over stock - Hold on while mashing gas!
You don't have to move anything to do this, mount it on the strut tower. Right there on the side is a screw hole, get a screw and put it on.
For 15 bucks it is the best mod and cheaper than a new coil!
Old Jul 27, 2004 | 10:03 AM
slashdawg00110's Avatar
RTFFAQ
Brian's right. Easy, cheap and effective. IIRC, there's a number of threads discussing this in more detail. Look at the FAQ thread, there should be a link to at least one thread on this. If you want to spend a bit more time & money, look at threads about DLIDFIS using an extra coil and ignitor (or HEI ignitors). If you don't need stock for aesthetic or racing class purposes, go with 2nd gen leading coil or DLIDFIS.
Old Jul 27, 2004 | 04:04 PM
Xavier8's Avatar
Never satisfied
very easy to go 2nd gen coil, to agree with the above posts. Bought a second coil today at the yunkyard cause my first one was acting up. I had to run through the distributor for about a week again and greatly missed the power afforded by the direct fire. Make sure to also switch to 2nd gen leading plugs. They go right in to a 12a without any problems. My single diamond coil ran funny when firing these plugs, but good old direct fire is back in action.
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
