Timing problems
Old Jul 22, 2004 | 12:57 AM
LongBoardLarry's Avatar
Timing problems
I recently replaced my engine and when setting the time the leading was no problem. I could not get the trailing to line up with its mark. It ran ok idled rough then today it started runiing even rougher and when accelerating it studders and doesn't wont to go above 3.5k.
I check the vaccum lines and they all look ok.
Please help
Old Jul 22, 2004 | 01:33 AM
IanS's Avatar
Ricer
May have bumped the vacuum advance on the dizzy while setting. Just a thought.
Old Jul 22, 2004 | 04:56 PM
Just check checked the vac lines.
Old Jul 22, 2004 | 05:35 PM
RotaryRyan's Avatar
DSM
what do you mean you cant get the mark to line up? Does it move when you try to adjust it?
Old Jul 22, 2004 | 10:13 PM
Yes, but it moves away, it is already ajusted as close as it will go.
Old Jul 23, 2004 | 10:30 AM
BigJim's Avatar
trainwreck
then your dizzy may be off a tooth. I had that issue, when we put in the dizzy it was turned 1 tooth, so for leading to be right the dizzy was turned all the wayt 1 way, and trailing wouldnt line up. You will probably have to pull ur distributor and retry.
Queppa
Nov 18, 2024 03:47 AM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
